Displays 4870X2 + 600W PSU
Discussion in 'Hardware' started by DorkSterr, 27 Mar 2009.
  1. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
    My friend really wants a 4870X2 after seeing how wee it preformed on Crysis, the problem is he has a 600W PSU and ATI recommends a 650W or greater. Will there be any conflicts if he purchase the GPU and powers it with a 600W Powersupply?
    PSU Specs:
    +3.3V@36A, +5V@30A, +12V1@18A, +12V2@18A, +12V3@18A,
    +12V4@18A ,-12V@0.5A, +5VSB@3.0A
  2. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    My friend is running an OC'd quad and a 4870X2 on a HX620, works absolutely fine. It could start struggling if he added a second card, though. :)
  3. heir flick
    heir flick Minimodder
    2 Feb 2007
    intresting, im thinking about getting a 4870x2 but was not sure if my hx620 would be ok or not, its good to hear of someone useing this combination
  4. O O 7
    O O 7 What's a Dremel?
    7 Dec 2008
  5. ricickle
    ricickle Reamer
    27 Mar 2008
    Well im running 2 gtx260s fine on a 620w power supply so im sure the 4870x2 would be fine.
  6. hendi5689
    hendi5689 What's a Dremel?
    16 Mar 2009
    Good link 007. The graph shows the 4870x2 using aprox. 450 watts under load. Take into account the cpu and all the other goodies in the system and there could potentially be problems. There are many good deals on newegg for psu's. Up to you of course still, but if that was me i would do some more research.
  7. ricickle
    ricickle Reamer
    27 Mar 2008
    i think thats full system load not just the card
  8. DorkSterr
    29 Nov 2008
    Alright thanks so much guys, Ill tell him to give it a try.
  9. Top Nurse
    Top Nurse Minimodder
    31 Mar 2005
    Not all PSU's are rated the same. Thus there is no real comparison.
    I have a 510 watt PSU that would run that just fine. The higher wattage advertised PSU you get just gives you more of a finagle factor if you don't know how to figure out your own power draw.
  10. Snuffles
    Snuffles Dreamy Mammoth
    24 Feb 2009
    The owner of the local computer store has
    i7 920
    2x GTX 295
    6 HDDs
    3 opticals
    12 Gbs RAM
    X-Fi
    Raid card
    all running off a 750
    So I would assume if its a Quality PSU you should be fine.
  11. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    The 4870X2 has a TDP of around 270 watts, so you will potentially need over 22 amps to be on the safe side. Your friend's PSU only has 18 amp rails, so unless the PSU uses 2 rails for PCI-E connections, you may have to use a Molex to PCI Express Adapter.
  12. mm vr
    18 Nov 2007
    Holy mole, 752W with two 4870X2's! :eeek: If I'm getting two of 'em I'll propably have to upgrade my PSU. :(
  13. wyx087
    15 Aug 2007
    what exactly is the make/brand of the powersupply.
    Corsair Hx620w = no problem with any single card
  14. DorkSterr
    29 Nov 2008
    It's An OCZ GameXStream 600W
  15. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I'm running a pair of 4870x2s on a PC Power and Cooling Silencer 750. Currently benching this morning, and no issues.
  16. mm vr
    18 Nov 2007
    Try FurMark, and remember to rename the EXE to something that is not FurMark.exe and that has a CF profile and is OpenGL, such as etqw.exe.
    Why? Because ATI drivers slow down the GPU when running FurMark.exe to protect the card (the VRM's on the 4870 overheat!).
    Also, FurMark.exe doesn't have a CF profile, but etqw.exe (Enemy Territory: Quake Wars) has, and they are both OpenGL so there shouldn't be any problems.
    Oh, and also run Intel Burn Test or at least Prime95 while stressing to max the power needed to run it. :)
