Graphics 4870x2 Second core always idle
Discussion in 'Tech Support' started by eagleuk, 20 Oct 2010.
  1. eagleuk
    eagleuk New Member
    20 Oct 2010
    I recently bought a 4870x2 card,
    I cleaned all the ATI drivers off my system etc. etc. downloaded the latest drivers and installed.
    I have both cores showing up and it they show up correctly in CCC one as primary and one as linked adapter.
    The problem is the second core always sits idle and I can't seem to get it too use it.
    I know it may not be support in all games but I can't get anything to use it even 3dmark!
    Any ideas?
    Thanks in advance!
  2. eagleuk
    eagleuk New Member
    20 Oct 2010
    Still haven't got any further :(
    Anyone had any experience with this card?
  3. PhoenixTank
    PhoenixTank From The Ashes
    5 May 2010
    Did you grab and install the latest Catalyst Application Profile too?
  4. eagleuk
    eagleuk New Member
    20 Oct 2010
    I installed ATI Catalyst Application Profiles yes :)
  5. eagleuk
    eagleuk New Member
    20 Oct 2010
    As far as I am aware they should activate themselves?
  6. nightblade628
    nightblade628 Member
    10 Dec 2009
    I would drop an e-mail to AMD tech support and ask them directly, I know on Nvidia drivers in the past it had an option to use either one Core or both, and how to split the workload between the two (split frame rendering, alternate frame rendering, etc.) There should be an option somewhere in Catalyst I would hope.
  7. PhoenixTank
    5 May 2010
  8. eagleuk
    eagleuk New Member
    20 Oct 2010
    Got the second core working but...
    The card never seems to work at max?
    The second core goes to about 20-30% in games no higher,
    So in games like cod4 I cannot hit the magic 250 fps :(
    Any ideas what could cause that? I turned ULPS off already.
  9. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Why do you want 250fps???
    You won't see more than 60fps if your monitor has a refresh rate of 60Hz.
  10. eagleuk
    eagleuk New Member
    20 Oct 2010
    I know that ^ but it does make a difference
    Anyways it doesn't really matter about what I can or cant see it should still be doing it :)
