4G modem advice
Discussion in 'Hardware' started by Cptn-Inafinus, 25 Mar 2018.
  1. Cptn-Inafinus
    Cptn-Inafinus Member
    3 Mar 2007
    Hello all, first time I’ve logged onto Bit-Tech in about ten years. The last time I was here it was all talk about cheesecake and the GeForce 8800 was new. Heady days.
    Looking for some advice re 4G modems; I understand the basic premise, but I’m a little unsure re SIM cards. Does a 4G modem use up your tethering allowance or your regular data allowance?
    Also, if you have any suggestions re a permanent outdoor modems for rural locations, do let me know.
  2. Mister_Tad
    Mister_Tad Super Moderator Super Moderator
    27 Dec 2002
    Depends on your tariff, but generally any 'home broadband' sort of use will hit your tethering allowance, or possibly just be insta-throttled, without the right tariff.
    I use LTE as my primary broadband, as it happens just recently posted a brain dump on it.
    https://forums.bit-tech.net/index.p...nd-tribulations-of-wireless-broadband.341972/
    It's definitely workable, but lots of caveats. On the plus side I've worked through most of them so you don't have to :thumb:
  3. Cptn-Inafinus
    3 Mar 2007
    Boff, that’s quite a read! Thanks for the advice.
