4gb ram in 32-bit vista
Discussion in 'Hardware' started by delsinboy, 1 Mar 2007.
  1. delsinboy
    delsinboy intermediate selfbuilder
    25 Feb 2007
    i was advised recently in this forum that i couldn't use 4gb of ram (4x1gb) in 32-bit vista. is this correct?
    i'm self building:-
    asus p5b
    e6600
    vista home premium 32-bit
    .. and i was planning to get 4gb of ram.
  2. DougEdey
    5 Jul 2005
    You can, but it won't recognise all 4GB.
  3. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    Isn't it something liek 3.23GB that gets recognised?
  4. delsinboy
    25 Feb 2007
    so if i get 3gb will it recognise all 3?
  5. Axel
    Axel What's a Dremel?
    20 Feb 2007
    exactly
  6. DougEdey
    5 Jul 2005
    Yea, 4294967296 bytes can be recognized by 32-bit addresses. But Windows will only be able to address 3.2GB of it due to overheads of addressing. You can change a switch to increase it, but it can cause problems with programs.
  7. delsinboy
    25 Feb 2007
    ok thanks very much - i'll get 3.
  8. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    get 4... 4x1gig in dual chan will be faster than 3...
    plus windows can only give 2gig/thread (or at least in xp/2k3) so you will have the ability to have 2 threads using quite a lot of ram - Win2k3 sees 3.5 gig of 4gig btw :)
  9. kempez
    kempez modding again!
    4 Aug 2005
    According to this site Vista supports more than 4gb RAM
  10. Dreaming
    Dreaming What's a Dremel?
    31 Jan 2007
    Yea, it does explicitly say in the table that Windows Home Premium 32 bit edition supports a maximum of 16gb of ram.
    Not sure whether it's true or not thoguh.
  11. Jipa
    5 Feb 2004
    16 gb = 2 GB ;) If that's not a typo then maybe it means the Home Premium works even there's 16 GBs of ram, but won't boot if there's 17 GB!
    The point is how much is the amount it can utilize correctly I guess.
  12. Mother-Goose
    22 Jul 2004
    Vista 64-bit supports 16gb of ram due to 64-bit memory addressing. I think I am right in saying that it is ONLY the 64-bit edition that supports 16gb.
  13. kempez
    4 Aug 2005
    Uhuh since it's 32bit it will see the amount that the OS can successfully utilise
    http://windowsmvp.spaces.live.com/blog/cns!80195647FE07388F!157.entry
    If only there was more support for 64bit ey?
  14. Mother-Goose
    22 Jul 2004
    vista 64-bit support is alot better than people are saying AFAIK, you don't see many people bitching about it
  15. DougEdey
    5 Jul 2005
    The main problems I have with 64 bit are webcam and DTV drivers. That's all. Untill they are sorted, I won't be using it.
  16. kempez
    4 Aug 2005
    It's not too bad but if you have a creative sound card then you're screwed...the 32bit version of the drivers is bad enough currently :p
  17. cjmUK
    cjmUK Old git.
    9 Feb 2004
    My Vista Ultimate x64 supports 128GB. Only the Home versions have their wings clipped at 8GB & 16GB.
    Correspondingly, ALL x86 versions are limited to 4GB.
    http://news.softpedia.com/news/Windows-Vista-Maximum-Supported-RAM-44487.shtml
  18. Boswell
    Boswell Minimodder
    23 May 2005
    hmmm 32bit will have a tech max of 4GB cjmwork2...so unless there is a home 64 bit (which there could be... I don't know though)... then you are wrong.
    You guys might be confused when someone says 16gb. Jipa explains it but i'll say it in a full sentance... 16 gigabits is not the same as what we normally talk about... gigabytes - to convert gigabits (gb) to gigabytes (GB) you have to divide by 8...16/8 = 2 GB.
    :) Ed
  19. Mother-Goose
    22 Jul 2004
    hmmmz didnt know that Ed, I had thought it was 128GB but when no one else said it i thought i may have been dreaming it lol
    128GB is yet another advantage of ultimate.
  20. cjmUK
    cjmUK Old git.
    9 Feb 2004
    I think you need to re-read it.
    All x86 version are limited to 4GB; x64 version limits range from 8GB to 128GB depending on your version.
