Electronics 4N25 Optoisolator Limits?
Discussion in 'Modding' started by Beefy, 6 Apr 2004.
  1. Beefy
    Beefy What's a Dremel?
    6 Apr 2004
    Greeting fellow modders.
    I'm building a multi-voltage fan circuit that requires the isolation of both sets of fans. I planned on using 4N25 Optoisolators from Fairchild Semi-conductor but I have can't seem to figure out what the max current I can pass through each 4N25. I figure the max current for any circuit will be about 1.5-2 amps (2 high flow fans).
    What do you think boys? Will I have to consider using relays instead?
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Definitely need to use relays. Max current the emitter can handle is 100mA. You'll be hard-pressed to find 80mm fans that only draw .1A, and it gets more and more impossible as the fan size increases.
  3. DanielArdelian
    DanielArdelian What's a Dremel?
    17 Mar 2004
    4N25 are very low power optocouplers. These can handle only a couple of milliamps output current (< 10 mA). :nono:
    If you need to drive a relay, use 4N33 optocouplers, those have a darlington pair for the output transistor and can handle up to 100 mA continuous collector current. Do a google search for "4N25 datasheet" and "4N33 datasheet"... :thumb:
    The 4N25 has a "transfer current ratio" of about 20 %, which means that
    100 * (IC / IF) = 20 => IC ~= 0.2 IF at best. :D
    IC = Collector (output) current
    IF = Forward (input) current
    For IF = 10 mA (typical value) => IC = 2 mA
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    It's easy enough to boost a 4N25 with a small transistor, R1 above limits the opto Ic to about 2.3mA which will supply at least 230mA to any small fan or relay used as load R2. A relay will need an anti-back-EMF diode across the coil (band end to positive). ;)
  5. Beefy
    6 Apr 2004
    Thanks guys! I'm actually in a position where it's either relays or Optoisolators so I geuss I'll take the relay route then. Too bad I can't find a company that will give me samples of some relays like I can get the ICs :(
