4pin floppy removal
Discussion in 'Hardware' started by Ducarii, 11 Apr 2004.
  1. Ducarii
    Ducarii What's a Dremel?
    19 Feb 2004
    How do you guys remove those damed pins, there so tiny and..pin like. I tried using a needle but I can't get it, anyone got a trick they know?
  2. kenshin
    kenshin Banned
    22 Feb 2004
    ok there should be an exposed bit on the connector.get a knife and use the tip to push down as hard as you can at the bit nearest to the end of the connector. Gimme 5 mins and il get a photo
  3. Ducarii
    19 Feb 2004
    Near the end by the wires, I assumed it was a reverse barb, like on the big 4pin ones, I tied pushing down but was getting know where, I'll get my knife out.
  4. Ducarii
    19 Feb 2004
    wow, got it, those were some tough suckers, thanks for the help man :D
  5. kenshin
    kenshin Banned
    22 Feb 2004
    bah you beat me to it. Ah well il post it anyway
    You have to make sure you are pushing down on the bit nearest to the end.
  6. Ducarii
    19 Feb 2004
    Yeah, thanks again, I still don't know how to remove the types of pins on the power type plugs, for the mobo that is, I got a uv set of molex's thats why I'm asking, the 20pin plug has no little inlets to push, I don't suppose you know how to get those out as well? :baby:
  7. kenshin
    kenshin Banned
    22 Feb 2004
    ok here goes,
    1)get a staple (ive found the thinner ones are better)
    2) bend it so thats its in a shape like a U
    3)Make it so it just about fits inbetween the outside of the pin and the plastic connector on both sides of the pin at once. Each pin has two tabs that when the connector is layed horizontal is parallel to the long edge of the connector. You should be able to see these tabs anyway if you look closely.
    4)Wiggle it about :baby: while lightly tugging on the cable.
  8. Ducarii
    19 Feb 2004
    Ok I'll give that a go, thanks, thats a really jankey solution lol, too bad they don't make them like molex so you can use that tool or something, oh well. :)
  9. kenshin
    kenshin Banned
    22 Feb 2004
  10. Ducarii
    19 Feb 2004
    ah, damn it lol, of the 2 tools I could have chosen, why oh why couldn't I have gotten that one. :wallbash:
  11. Ducarii
    19 Feb 2004
    I tried a staple, wouldn't fit in both sides at once, so..oh well lol, I'll think of something. :rolleyes:
