Modding 4pin housing
Discussion in 'Modding' started by bluc, 15 Feb 2013.
  1. bluc
    bluc What's a Dremel?
    4 Apr 2012
  2. faugusztin
    11 Aug 2008
  3. bluc
    4 Apr 2012
    Have been considering that type but don't know if it will be as neat, going on highly visible cable.
  4. faugusztin
    11 Aug 2008
    bluc likes this.
  5. bluc
    4 Apr 2012
    Awesome thanks kicking myself I bought another lot of stuff earlier today from there but could not find these on the site at the time thanks for your help much appreciated :rock:
  6. faugusztin
    11 Aug 2008
    If they didn't ship yet you could try to contact them. I had very positive experiences with FrozenCPU, one of the cables i ordered from them has been delivered damaged (one of the pins was disconnected), few hours after i asked how to do the RMA i got the answer that they already shipped a replacement for free :).
  7. bluc
    4 Apr 2012
    Says in t&c that you have to phone to alter order. Would cost more than the $8 postage to ring from Australia to the U.K :) Did consider it though. Now just to buy some wire locally and wait for these connectors to arrive and I can move forward with my project.:dremel:
  8. kinghong1970
    kinghong1970 Just a Clumsy Ape
    19 Apr 2009
    digikey.com
    mouser.com
    but finding the part... that's another story...
    they are quite... well stocked...
  9. bluc
    4 Apr 2012
    Have major issues trying to find anything on those sites :) its fairly easy when you know the proper name for things, not so easy when you don't :) ended up buying from frozen cpu cheers.
  10. kinghong1970
    19 Apr 2009
    yea i too have to spend hours just trying to find what i need...
    sorry i couldn't be of much help...
  11. bluc
    4 Apr 2012
    Is there any guides etc for making your own cables which pin is for what housing is there a male and a female pin for the small 3pin and 4pin fan connectors? Got the housings right but a little stuck on how the pins work(I know you crimp them but don't know how the pins mate together male and female?). Help appreciated.
