M8, get the 14dBa ones, the thermistors are crap! you wont hear 14 anways (might be the 11's that have connectors to "mod" them to 14, will have to check up on that though) Bah, CBA to tidy, and TBH they dont restrict airflow at all....
The 14's are out of stock ill just have to wait not sure about the money situation this month as im saving for my holiday, all i know is that i can defo get the sp97 and a 92mm fan i cant decide between a silentX or and energmax
Z, any ideas where the case temp is taken from on the infinity? Is if the northy or is there a sensor somewhere?
Howdy. Newbie to these forums, so high to all ! Can i ask what that centre fan is attached to? Looks from the pic like it's just sat on a card Ta muchly Oli
Its attatched to a zalman fan bracket m8 You can see it snaking off to the rear of the case where is screwed to 3 PCI bays.
welcome to the forums.... not having had one of them before, this might be a longshot, but i imagine the bracket that attaches the fan to the case, also gets attached to where the expansion cards are screwed in...
Nothing like a funky desk setup eh Bigz I found i could get freakily good temps with my alphaPAL when i pointed enough fans at it OT: Another Oliver from Sheffield posting on Bit... weird.
Mines dropped another 4°C with the case side off now mmm chilly! Doin a windowsil bench when I get hold of a PSU and HSF, should keep the 1 gig duron nice and cool (as long as it doesnt fall out) Should have another alpha on the way as well
Erm well the ram seemed to perform rather nicely, it did UP to 215 fsb on 2,2,3,11 but nothing more, relaxing the timings, zip nada. Adding more voltage made things worse that was 3500 EL, and it wouldnt post its rated speeds at all, not even with 2.8v..... Seems like good stuff, nice bandwidth, fine to work with... will know more when mine returns...!
Sorry to post a bit OT, where are you guys getting your silenX fans from...I've yet to find a supplier in the UK, and I have spent a while looking...I'll probably kick myself as it'll be somewhere obvious but I haven't been able to track down a supplier. I'm after a couple of 120mm ones for when I get my SLK-3700BQE case
