Electronics +5/+12V/-12V DC PSU required
Discussion in 'Modding' started by Risky, 10 Jun 2005.
  1. Risky
    Risky Modder
    10 Sep 2001
    I need a small PSU for a small PC
    +5V 7A
    +12V 0.7A
    -12V 0.1A
    Any idea where I could find one on the cheap?
  2. star882
    star882 What's a Dremel?
    19 Mar 2003
    Have you tried going to a local computer store?
  3. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    star882 is probably refering to an ATX power supply, you might even have one lieing about in ur house. Just turn them on (green wire to ground) and you've got a +-12v -+5v.
    The old AT one is perfect, +5 -+12v.
  4. Risky
    Risky Modder
    10 Sep 2001
    I do have one or two PSUs about.....
    However what I have is a few very SFF machines, but rather fewer PSUs, and those I have are making alarming ticking noises!
    I could get a http://www.mini-itx.com/store/?c=10#p1802 but I don't need the whole ATX supply and wondered if I could get anything a bit cheaper to do the job.
  5. Ghlargh
    Ghlargh What's a Dremel?
    16 Nov 2003
    You probably won't find anything cheaper retail with those dimensions, You could probably buy old AT supplies at some local electronics junkyard for about 2 pounds, but those are larger.
  6. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    whats it presisly you need?
    I just so happen to have some snap in 120w dc-dc convertors with ATX plugs, there designed for VIA edens, and totaly silent.
  7. Risky
    Risky Modder
    10 Sep 2001
  8. nleahcim
    nleahcim What's a Dremel?
    22 Apr 2003
    at work I have an industrial power supply with really similar specs to that - and it's really small too - but I bet it'd be quite spendy to buy.
