Modding 50 quid for some LEDs! I dont think so!
Discussion in 'Modding' started by blueIce, 7 Oct 2001.
  1. blueIce
    blueIce The ICE man
    11 Sep 2001
    My god 16 blue leds will cost me a 50 note! JESUS! Any where cheaper than maplin?
  2. RolloThomasi
    RolloThomasi What's a Dremel?
    7 Oct 2001
    Blue leds are expensive...
  3. blueIce
    blueIce The ICE man
    11 Sep 2001
    I KNOW! Thats a rip off, white ones with die on the end could be cheaper, anyone know of how to do this?
  4. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    try RS Components
  5. blueIce
    blueIce The ICE man
    11 Sep 2001
    is that uk based do you know? Note my quote!
  6. Rod10k
    Rod10k What's a Dremel?
    2 Jun 2001
    yes, rs as in radio spares is UK, rs as in radio shack is US. I beleive that Tandy used to be radio shack in the UK but i think they have closed down.
    Radio Spares
    Rod
  7. Bursar
    Bursar What's a Dremel?
    6 May 2001
    You're obviously shopping at the wrong place!
    Rapid Electronics have the following 5mm blue LEDs:
    Code:
    Colour           Order Code    Brightness    1+      25+
    Water Clear      55-1490       1000mcd       0.99   0.75
    Diffused         55-1480       60mcd         0.70   0.52
    Bright Diffused  55-1495       450mcd        0.99   0.75
    Transparent      55-1485       80mcd         0.70   0.52
    Light Blue       55-1482       100mcd        0.70   0.52
    If you need any more info about the LEDs, let me know. You can contact Rapid on 01206 751166. They really are a fantastic company to order from. Very fast and professional service. The prices are ex VAT, and there's a £2.50 delivery charge on orders under £30.
    All good modders should really have one their catalogues (£3) as they have a fantastic range of kit :)
  8. blueIce
    blueIce The ICE man
    11 Sep 2001
    Thanks for the info Bursar - GREAT STUFF THERE. Can you give me anymore info on the Light Blue?
  9. Bursar
    6 May 2001
    No probs. The light one has the following specs:
    Code:
    IF max.   VF typ.   VF max.    VR max.   view angle    wave length
    30mA      4.5v      5.5v       5v        16 degress    430mm
    You'll need some 470 Ohm resistors if you want to run them from the 12v line in your PC, so you might want some of those too...
    CR25 0.25w carbon film resistors
    470 Ohm
    Order Code: 62-0362
    Pack of 100
    60p + VAT.
  10. blueIce
    blueIce The ICE man
    11 Sep 2001
    Thanks again, So much help!
  11. ChriX
    ChriX ^
    30 Aug 2001
    Hmmmm™ methinks im going to pur-chase a Rapid catalogue, it would be v. useful seeing as their website is not up yet.
    -c
  12. Cheese
    Cheese Doc
    6 Oct 2001
    ?? http://rswww.com
    works for me :)
    r.
  13. Cheese
    Cheese Doc
    6 Oct 2001
    I'd also recommend farnell - http://www.farnell.co.uk
    They had around twenty pages of leds last time I was browsing their catalogue :)
    Cheers,
    r.
  14. Cheese
    Cheese Doc
    6 Oct 2001
    lol yes... a search for led just turned up over 1000 products. Cool.
    r. :cool:
  15. RolloThomasi
    7 Oct 2001
    Just to clear things up; I thought white leds are more expensive than blues. Think I have read somewhere that to make a white led, you first need a blue one, and then add a layer of some crystals or something that gives off a yellow shine when energized. Blue+Yellow=White.
    Long story short: A white is actually 2 leds in 1, or something along those lines. Or I may be way off :)
  16. Bursar
    6 May 2001
    I bought two white LEDs from Rapid, and they weren't cheap.
    A couple of quid each IIRC. I haven't installed them yet, as they came with a whole A4 sheet of safety instructions with regard to handling, storage and installation :eek:
  17. blueIce
    blueIce The ICE man
    11 Sep 2001
    Well the rswww seem to have nice 'n cheap ones - or may be JPR electronics as well. I duno, PICs here soon!
  18. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    Yep Farnell they rock ;)
  19. Cheese
    Cheese Doc
    6 Oct 2001
    Yes they do! But their website is even worse than rs's - their paper catalogues (all six of them? Maybe five) are far far more easy to browse :D
    r.
  20. ChriX
    ChriX ^
    30 Aug 2001
