Build Advice 500£
Discussion in 'Hardware' started by enfluence, 19 Nov 2010.
  1. enfluence
    enfluence Minimodder
    31 Aug 2009
  2. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
  3. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Yup, the all rounder will do you very well :)
  4. Dae314
    Dae314 What's a Dremel?
    3 Sep 2010
    Are you considering Windows 7 in the cost too?
  5. enfluence
    31 Aug 2009
    Already got windows 7 paid for and from looking at the all arounder it has quite a few things i dont really need so i could up it a little bit.
    from reading issue 86 of Custom PC I've been looking at the I5 760 (seems to be cheaper than the mentioned 750 from what ive researched)
    The Corsair XMS3 PC3 - 12800
    the Antec TruePower TP -650
    ATI Radeon HD5770 (Theres a new range, might be better?)
    And I've tried looking at the GA-P55M-UD2 mentioned in the magazine but i can't seem to find it in the quick time i've had to look.
    My question is, is there anything better since the release of this magazine? Because all I really need is a PSU, GPU, RAM, MOBO and CPU, everything else is accounted for.
    PS I am looking at overclocking.
    Edit:
    Also I can wait for awhile if anything drastically better or cheaper/better is coming.
  6. Dae314
    3 Sep 2010
    It's going to be a budget stretch to get an i5 build at £500
    i5-760 - linky
    MSI P55A-G55 - linky
    or
    Asus P7P55D-E - linky
    Some 2x2GB 1600MHz memory - linky
    Antec TP-650 - linky
    6850 (because 6870 is breaks your budget) - linky
    or
    GTX 460 - linky
    Thermaltake Frio (you forgot a cooler if you're going to OC) - linky
    or
    Gelid Tranquillo - linky
    Turns out to be about £550
