Storage 500GB SSD, too many choices
Discussion in 'Hardware' started by modd1uk, 6 Apr 2015.
  1. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Going to ditch the 1TB HDD storage drive out of my rig, my server has enough storage for me to replace my main rigs storage drive with an SSD.
    What's the favourite drive atm ?
  2. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    Samsung 850 EVO 500GB.
    can be had for about £155
  3. Bradley8988
    Bradley8988 What's a Dremel?
    16 Jun 2008
    Agreed. Although the 840 has some problems the 850 seems fine so far.
  4. ak_2020
    ak_2020 Minimodder
    22 Nov 2010
    +1 on the Samsung 850 Evo.
  5. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    Even though I don't own one, another vote for the 850 Evo :)
  6. PocketDemon
    PocketDemon What's a Dremel?
    3 Jul 2010
    Unless you've very specific usage requirements &/or happen on a bargain then the 850 Evos are very decent drives... ...& the extra cost vs something like the Crucial MX100 is so small atm as to make the Samsung a much better buy for an average usage d.t. the better performance.
    That said, if you've got an extremely heavy workload there's better drives, like the 850 Pro...
    ...or, as a personal example example, d.t. needing to run one of the SSDs in non-trim on a recent build, then i ended up getting a 512GB Plextor M5Pro along with a 500 850 Evo - not because the M5Pro was the best drive out there, but there were budgetary limits (& i found a bargain, as new & from a reputable retailer then it was less than the Evo was) & they're *much* more resilient than the Samsungs in non-trim.
  7. Bradley8988
    16 Jun 2008
    Really doubt you will notice anything between any modern drive as they have saturated the interface. Sometimes the pro can be not much more cost wise so maybe worth looking out for one of those also.
  8. Otis1337
    28 Nov 2007
    the 850 versions price difference with EVO/PRO is quiet big atm.
    The 850 EVO is a stellar driver with nothing but there own PRO drive been in there performance category within SATA3
    (Admittedly when you are at the speeds most top end SSD's are at you wont see a real difference apart from in benchmarks tho)
    Id just like to say as well, if reliability and rock solidness is more important to you than blazing performance Intel is unrivaled, undisputed king in this respect. There drives are server grade and put under extreme vigorous testing before release which most SSD manufacturers wouldn't dare. In speed tho, a Samsung EVO or PRO would win in all tests
  9. silk186
    silk186 Derp
    1 Dec 2014
    I'm running an 830 which is pretty old but not even worth updating to anything sata3.
    If you are going sata3 get what ever is cheapest that has a good name Intel, Samsung, Crucial, plextor...
  10. PocketDemon
    3 Jul 2010
    Ummm... An 830 is a 6Gb/s (aka sata3) ssd...
    if, instead, you're talking about the OP getting a 3Gb/s one then there certainly is a noticeable difference between the best of them & a decent 6Gb/s one - &, separately, i could certainly tell the difference between 2x 120GB V Turbos in R0 -> 4x 50/60GB V2s in R0 -> 2x 256GB 830s in R0 -> & 2x 256GB 840s in R0... ...but, the difference became less & less each time outside of some very specific tasks.
    Well, naturally none of my tasks are to b/m the drives for kicks & giggles... ...but instead, even with an old o/c'd 3770K (or previously a o/c'd 2600K), there's things i do that take bunches of time where the disk bandwidth is the limiting factor - whereas others it'd be the cpu or memory or gfx card or whatever...
    ...so it's incorrect to suggest that they're all much of a muchness as it's all about usage.
    That said, as with most tech, you should aim to buy on the basis of budget, features & need...
    So, whilst the other 4 Samsungs are still in use in another machine, the needs for the recent build i mentioned were about decent enough performance for a more limited set of tasks, needing two 500/512GB drives (one where trim would be enabled & one not) & cost...
    ...but with the 850 Evo being faster, using more robust nand & with a longer warranty than the MX100, it was a pretty obvious choice to spend an extra couple of quid on the noticeably better featured drive for the one that'd have trim enabled... 'bang for the buck' & all.
