PSU 500W enough?
Discussion in 'Hardware' started by matt_lumley, 7 Aug 2013.
  1. matt_lumley
    matt_lumley You're only supposed to...
    28 Apr 2010
    Hi guys,
    I am getting further into planning my build now (some of you may have seen my recent threads in the market place) and I have one small niggling question.
    Will a 500W PSU be enough to power:
    1 SSD
    1 HDD
    1 M-ITX Mobo
    8GB RAM
    2 FANs
    1 i5 2500k/3570k
    and the potential to upgrade and use a 7850 when the prices are a little lower?
    What do people think?
    Matt
  2. jbloggs
    jbloggs What's a Dremel?
    12 Sep 2007
    Yes...
  3. matt_lumley
    28 Apr 2010
    Anyone else got an opinion?
    Sent from my GT-N8010 using Tapatalk 2
  4. Tangster
    23 May 2009
    Also yes.
  5. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Take a look at this site
    Personal I usually go for over kill because I don't plan on replacing my PS until the one i have is overloaded or dies. You never know what you will put in your comp that takes More POWER!
  6. LightningPete
    LightningPete Diagnosis: ARMAII-Holic
    2 Jul 2009
    Make sure its a decent PSU and its heavy to hold. I know it sounds daft but a heavy PSU is a good indiciation of a decent one. Getting a 500w PSU with only 20A on the 12v+ rail is really crap basically. So check there are suitable amps for running an i5 system (+any GPU in the future if necessary)+(any overclock)
