50th Anniversary Stacker
Discussion in 'Project Logs' started by coolmiester, 10 May 2007.
  1. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Personally, I reckon you should leave it as is - I'm also a fan of clean designs, and you've hit that style spot on with this case.
    Have you thought about painting the wheels black? They look a bit out of place at the moment in contrast to the black/yellow/white case.
  2. Dira
    Dira What's a Dremel?
    1 Sep 2005
    Like the clean look! The front could use just something small.
    Will it have any lightning effects? :)
  3. RonaldoR9
    RonaldoR9 What's a Dremel?
    17 Dec 2006
    amazing mod the rad would look pretty cool if you were able to mount it somewhere on the outside like the front and placing the fans underneath so all you would see would be the radiator fins or even on the sides
  4. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    god this is a great mod
  5. Big SturL
    Big SturL What's a Dremel?
    15 Jul 2005
    Do you use any special techniques or tools when painting?
  6. Dira
    1 Sep 2005
    Start from page 1 ;) He has done a great job! Lots of patience! Covering great! Letting it dry :thumb:
  7. Mr. Oizo
    Mr. Oizo That yellow furry animal-thingy
    18 Mar 2007
    WOOOT! This case is looking HOT! The paintjob is amazing! Looks really good!
    What are you gonna do with the front?
  8. Darkened
    Darkened What's a Dremel?
    28 Feb 2004
    Damn Paul, you move fast :hehe:
    The Stacker is looking really good, can't believe that you are painting it with a normal "rattle can" paints. Btw. what brand of paint do you use with this?
    Do you have a deadline with this project, I was just wondering cause you are modding it really fast?
    I'm looking forward to seeing what you're going to do with the innards of the case.
    Darkened
  9. Xlixen
    Xlixen What's a Dremel?
    16 Apr 2007
    That.is.sweet :D
  10. TNash
    TNash What's a Dremel?
    12 Mar 2007
    wow, looks awesome...
    good work!
  11. D B
    D B What's a Dremel?
    11 Apr 2004
    Dang! That's Sweet!
    ... ooooh and I like yellow too
    You've captured the look of the bike perfectly as it is , do not add too much as I think it will detract from the clean fast look that it has
    DB
  12. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    have the rad mounted up front and mimic the yamaha rad perhaps?? i dont know if there are any shrouds on it, but that is my best guess.
  13. hellas91
    hellas91 What's a Dremel?
    18 Feb 2006
    Beautiful work, as usual ;)
  14. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Decided to do a bit with the fans while waiting on a few bits coming.
    Took a couple of Yate Loons which seem to be the fan of choice these days plus they are cheap as chips as i wasn't real certain how this would turn out.
    Used Pete's "how to guide" to dismantle the fans and gave them a coat of Plastic Primer which is clear but gives the paint a good key and then sprayed the fan bits all white while the frames got the yellow treatment.
    When the white was dry, masked off the edges of each blade with thin line masking tape and hit the exposed bits with black.
    I got a couple of genuine Yamaha tuning fork logos to go in the centres followed by a coat of clear coat and that's another job jobbed :D
  15. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    I was thinking black and white fans...sweet....but theses are even nicer!
    Deffo coming to yours to have some bits of my car painted....
    i need a white stripe down either side...
  16. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    thats just kl!!!
  17. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Lovin it. nice work as always coolmiester :hip:
  18. Duste
    1 Oct 2006
    You, sir, are a painting mastermind!
  19. Raymus
    Raymus What's a Dremel?
    29 Jun 2004
    Looks great Coolermiester. Where is this guide you speak of?
  20. Stubkier
    Stubkier What's a Dremel?
    23 Nov 2005
    wauw - those fans really look great. The colour choise is spot on :)
