512Mb --> 1Gb
Discussion in 'Hardware' started by Awoken, 23 May 2004.
What do you think?
  1. 1Gb of RAM is totally unnecessary
    13 vote(s)
    11.7%
  2. 1Gb the new standard
    98 vote(s)
    88.3%
  1. TheGod
    TheGod What's a Dremel?
    30 May 2004
    I have 1024MB TwinMos 400er in a 512 dual channel config on a Asus A7N8X-E Deluxe
    i don't have problems with newer games UT2004, Farcry everything is wonderful playable :thumb:
  2. Sniper-X
    Sniper-X What's a Dremel?
    27 Mar 2004
    i am rocking on with a whooping 328megs of 100mhz sd ram LOL :rock: god i need a new system lol
  3. TheGod
    30 May 2004
  4. KONIJN
    KONIJN What's a Dremel?
    30 Nov 2003
    i have a Gigabyte GA-8S648FX with 512mb ram (2x 256mb in dual channel)
    and i want to upgrade to 1024mb ram
    should i just put a 512mb ram stick with it or should i get rid of the 2x 256 ram and get 2x 512 ram in dual channel?
  5. TheGod
    30 May 2004
    is better if you take 2 x 512MB in dualchannel , but only if your board use dualchannel modus.
    but if you won't spend to much money you can also buy one 512MB, but then it's not so fast as dualchannel
    I have 2 x 512MB in dualchannel on a asus a7n8x-e deluxe
  6. neonplanet40
    neonplanet40 What's a Dremel?
    3 Mar 2003
    I have 1GB TwinX Corsair 4000Pro in dual channel and at 230 FSB 1:1 Ratio. Having problems getting my 3gig pentium 4 at 250 FSB but i can do it :) im on an abit ic7 max3 motherboard. i can multi task like mad on my computer :) no slow downs is always gr8 :p
  7. Kryai
    Kryai What's a Dremel?
    7 Apr 2004
    I'm using 512 of PC133 on a 1.2 Tbird, i'm aiming for building a new computer in the next 3-9 months and i'm getting atleast 1gig of ram and i've just recently started looking at the matched kits of 1024x2 for 2 gig. Only thing that make me apprehensive is the price tag. I'm also waiting on the price of this new generation of vid card to plunge to levels more reasonable. :sigh: For now i'm content with playing wc3/eq on this machine. WoW is most likely going to coincide with my comencing of component shopping! :hehe:
  8. CrapshoT
    CrapshoT What's a Dremel?
    26 Jun 2003
    To run Far Cry without any gliches or slowdown you need more than 512mb of ram which was unheard of.God i can remember when 128mb was a massive amount of ram.I'm starting to feel like my Dad.!!
  9. 0013
    0013 What's a Dremel?
    7 Mar 2004
    try "640 k should be ... " :D
  10. Guest-16
    Guest-16 Guest
    You can run farcry normally on 512meg of ram, ive done so.
  11. TheGod
    30 May 2004
    in lowest grafilevel it's also playable with 392MB - i do :)
  12. Pookeyhead
    30 Jan 2004
    Just tried that... it's perfectly playable, yes. It does improve a great deal with 1Gb tho.... seems less jerky when action gets heavy (end sublevel on the regulator level for instance), and levels load way faster. If I quickly quit farcry and go back to my desktop, I'm just in time to see MBM5 saying I've only got 100Mb or so free. It uses it if it's there, so having it can only be a good thing :D
