Graphics 560ti on 500watts
Discussion in 'Hardware' started by Exangels, 13 Oct 2011.
  1. Exangels
    Exangels What's a Dremel?
    13 Oct 2011
    I was wondering is it possible to run a 560ti on a 500watt power supply?
    it has 34a and 408w max ouput on the 12v rail
    My specs
    quad core q6600 2.4ghz
    g33t-am Motherboard
    2 segate Hard drives
    dvd-rw
    Corsair cx500v2
    evga 550ti (which i want to upgrade to 560ti)
  2. shrop
    shrop El Jefe of Sleeving
    22 Jul 2011
    I'm currently running an OC'ed MSI 560ti on a Corsair CX 500 no worries.
  3. LennyRhys
    LennyRhys Oink!
    16 May 2011
    I assume the 560Ti draws less than the 470, in which cas yes it's absolutely fine. My system with the 470 drew about 400W max; now with the 460 it draws 375W (furmark).
  4. Deders
    Deders Modder
    14 Nov 2010
    Easily, my system doesn't draw more than 380 from the wall when gaming, which is 323W from the PSU @85% efficiency. That is with an overclocked system.
    A 560TI draws 170w, so you'll be ok with a good 500W PSU unless you want to go SLI.
  5. 2ltJoel
    2ltJoel What's a Dremel?
    13 Oct 2011
    i read on the nvidia website that the minimum system power requirements for the gtx 560 ti is 500w. my psu has a maximum of 460w, so are you saying that i am able to use a gtx 560 ti even though my psu's max power is lower than the minimum recommended by nvidia?
  6. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    its all about the quality of the psu
    you could run something on a high quality 500w than wouldnt run on a low quality 650w.
    perhaps an exaggeration but you get the idea. if its a reputable brand you should be fine for that card
  7. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Funnily enough I just ran my signature rig through one of these and it tops around 450 watts with extreme stress on all components. Looking forward to the next series of GPU decimating my PSU for a real test! :D
  8. Exangels
    13 Oct 2011
    awesome thanks. Thinking of using Evgas step up program to get a 560ti after seeing the performance difference on the review
  9. Deders
    Deders Modder
    14 Nov 2010
    If you ran stressed all your components at the same time you would likely reach 460w if not more, causing the computer to switch off. but for general gaming use 460W would be enough, but it's nice to have the extra headroom so your psu will last longer.
  10. faugusztin
    11 Aug 2008
    It really depends on the maker of the PSU. But unless you got some OurPSUBlowsUnderLoad brand PSU, then your 460W should be just fine. My GTX570+i7-2600K uses 400W tops (MSI Kombustor+OCCT at same time).
