Graphics 580 sli to 590 switch out
Discussion in 'Hardware' started by Blarte, 23 Nov 2011.
  1. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    Gents and ladies ..
    Just a quick question, my rig is a z68genez Asus Board with a 2600k and two 580's in sli
    so they will be working at x 16 and x 8
    What if any would be the gain in switching out the two 580's for one 590 on the x16 slot?
  2. longweight
    7 May 2011
    IIRC running at x8 makes very little difference so I wouldn't think you will gain much at all.
  3. Blarte
    15 Jul 2008
    cheers ..
  4. favst89
    favst89 What's a Dremel?
    23 Jul 2010
    It is a very small difference and thinking about it more. Isn't a 590 2x 580's on one card therefore they will be sharing x16 between two cards? So 8x each. Probably doesn't work quite like that due to some memory sharing and data uploading to it but I can't see it being noticeable either way.
  5. Instagib
    Instagib Minimodder
    12 Mar 2010
    You'd gain the use of a 4xpci-e slot and the 8xpci-e slot, but lose out on about 600 quid and some performance.
  6. shaunster1011
    shaunster1011 What's a Dremel?
    26 Sep 2011
    And introduce a card that cant overclock without fear of melting it, of course.. :)
  7. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    lol bro you must be made of money. its definitely not worth the performance increase if any to drop £600 on a new card just to run it in x16
  8. Guest-44432
    Guest-44432 Guest
    2 GTX 580's will outperform a 590, even with your x16 and x8 configuration. So you would be mad to change...
  9. Allsopp
    Allsopp What's a Dremel?
    22 Nov 2011
    No point changing due to the cost and the chance of fire also might as well wait for the next Gen cards now.
  10. Blarte
    15 Jul 2008
    I'll sack that idea then huh lol
