CPU 5800X3D + X570 motherboard + ASUS Hyper M.2 x16 Gen 4 Card ?
Discussion in 'Hardware' started by grimerking, 21 Apr 2025.
  1. grimerking
    grimerking Minimodder
    26 Apr 2009
    Hi,
    This is my current system:
    AMD 5800X3D CPU
    PRIME X570-P motherboard
    AMD 6800 XT graphics
    4TB Corsair NVMe = connected to a motherboard slot
    1Tb Corsaid NVMe = connected to a motherboard slot
    256GB Toshiba NVMe = connected to PCIe adaptor.
    I've seen this device:
    https://www.asus.com/uk/motherboards-components/motherboards/accessories/hyper-m-2-x16-gen-4-card/
    There are quite a few reviews complaining about compatibility and the lack of available PCIe lanes.
    According to AMD my CPU has 20 usable lanes + 16 lanes for an X570 motherboard.
    https://www.amd.com/en/products/processors/desktops/ryzen/5000-series/amd-ryzen-7-5800x3d.html
    My GPU is installed in a 16x slot and (I think) that should leave me with 20 lanes for the NVMe drives. I presume that I'm currently using 12 lanes for the three NVMe drives that I have fitted.
    If I fit this card into the secondary 16x PCIe slot, is it as simple as removing one or both of the NVMe drives that are connected into the motherboard, disabling the slots in BIOS, and then fitting them into this card (JBOD)?
    Ideally, I'd like to configure it as RAID0 with four identical NVMe drives (e.g. four 1TB cards) and keep the existing 4TB NVMe connected to the motherboard. That would total 20 PCIe lanes, but I'm not sure if things are that simple.
    Does anybody have any experience with this?
    Thanks.
  2. wyx087
    wyx087 Multimodder
    15 Aug 2007
    No, it wouldn't touch the motherboard NVMe slots.
    On some motherboards, it will split the 16x across the 2 full length PCIe slots, giving both 8x lanes.
    But looks like your motherboard doesn't support this. The 2nd PCIe slot is from the x570 chipset at 4x.
    https://www.asus.com/uk/motherboards-components/motherboards/prime/prime-x570-p/techspec/
    The Asus NVMe card spec page talks about compatibility:
    What you can do is fit GPU into the x570 chipset PCIe slot (2nd one) at cost of FPS. Then fit this card into primary PCIe slot with CPU. It will achieve what you want.
    Alternatively, just buy a big drive and buy any NVMe PCIe adaptor for the x570 chipset PCIe slot:
    https://www.scan.co.uk/products/icy...card-with-m2-m-key-socket-for-one-m2-nvme-ssd
  3. grimerking
    26 Apr 2009
  4. sandys
    sandys Multimodder
    26 Mar 2006
  5. sandys
    sandys Multimodder
    26 Mar 2006
    scratch that comment on hyper m2 just read the manual
  6. sandys
    sandys Multimodder
    26 Mar 2006
    Also worth remembering that if you are raiding sata SSDs are still pretty handy, cheap and fast for raid0.
  7. wyx087
    wyx087 Multimodder
    15 Aug 2007
    Is there any reason why you want to RAID 0 four NVMe drives? What do you need such speed for?
  8. sandys
    sandys Multimodder
    26 Mar 2006
    Maybe for a large big disc, I do this for my games and temp drive (not system temp, but say big video holding area before I convert or upload) where I don’t care if I loose stuff and just have a big array of discs for all the data that I can just keep adding too. Who wants to look at loads of drive letters just give me a big old disc.
    Speed is nice when moving such data around your system or working with it, the slow points tend to be on and off the machine though but I at least have 20Gb link to my NAS for that when I am ultimately done.
    Even if you manage to fit more NVMe, you have to look at where your lanes are coming from on x570, some are off the main CPU, so the x4 on your board is on the chipset I'd imagine normally there is a board box diagram like below but I could not see it, I mean it mentions it is crossfire compatible so I would assumed an 8x/8x, but it does not say that in the manual.
    The lane arrangement, shows you where the lanes get spent, you don't get them all.
    If you put your GPU in x4 with all your services from chipset, the link to CPU will likely get saturated and you'll have bad system performance.
    Many boards will split the x16 to the second slot if you want more addin cards so you can run an 8x/8x/4x setup, giving 8x to GPU (plenty) and 8x to secondslot (great for card I mentioned) but I guess the prime P being on the lower end ASUS only wired this second slot for x4 which is a poor show on an x570 level chipset.
    wyx087 likes this.
  9. wyx087
    wyx087 Multimodder
    15 Aug 2007
    The card you linked has a PCIe bridge (I think?). Would that affect RAID performance vs 4x 4x PCIe bifurcation that OP wanted via CPU through the Asus card?
  10. sandys
    sandys Multimodder
    26 Mar 2006
    It has a MUX/PLX switch, it is not going to effect performance in any noticeable way bar of course bandwidth limitations of reduced lanes etc.
    Image from QNAP
    obviously using the top slot for full x16 straight to CPU is superior, I could do this in my NAS for example as I don't need a GPU, it has IMPI but I use both x16 slots in 8x/8x config one for extra dual NIC card I feed to router and one for that quad M2 card.
    With this card you don't need bifurcation support that might not exist on lower end.
    You used to get these chips on loads of boards then Broadcom bought the company and the price went exponential.
    If you want to see an actual x570 board chipset implementation this is my NAS board as an example of how things hang off
    X570D4U-2L2T.pdf p15 it has pretty pictures makes it quite clear.
    You can see a similar mux chip fitted on the mobo between the board slots to give the lane config.
    wyx087 likes this.
  11. grimerking
    26 Apr 2009
    Not really.
    I'm running out of space on my NVMe drives and I don't have any spare slots. It made me wonder if there were any PCIe NVMe RAID cards available.
    This item was £44 yesterday, but has increased in price.
    https://www.amazon.co.uk/KIOXIA-EXCERIA-PLUS-SSD-1TB/dp/B0CN5L6FPK
    The RAID card is £57
    https://www.amazon.co.uk/ASUS-M-2-supports-devices-platform/dp/B0863KK2BP
    £233 for 4TB of RAID0 NVMe storage seemed like a good deal.
    It looks like my motherboard is a problem and I can't justify a complete system upgrade. My current system is 'good enough' for my day-to-day usage.
  12. sandys
    sandys Multimodder
    26 Mar 2006
    you can get a couple of 2gb sata ssd and raid0 on your existing sata controller for less if you just reasonablly fast space, yes sure, its not NVMe fast but it's no slouch.
    wyx087 likes this.
  13. wyx087
    wyx087 Multimodder
    15 Aug 2007
  14. sandys
    sandys Multimodder
    26 Mar 2006
    Or just transfer your small ones to a big one, get rid, now you have a free slot for next one, blimey, there are games that fill 256Gb :D
  15. grimerking
    26 Apr 2009
    I use the 256GB drive as a 'sacrificial' boot drive. If Windows kills it with excessive write operations, then it's only £20 for a new one.
    I take your point, though. I could dump the 1TB drive and replace it with a 4TB drive.
  16. wyx087
    wyx087 Multimodder
    15 Aug 2007
    Everything move up the stack?
    Make 1 TB the boot drive, you then also gain 700 GB for storage.
    These days the write lifetime is pretty high, no need to worry about wearing out the drives.
