Graphics 5870 or 5870 2GB EYEFINITY 6
Discussion in 'Hardware' started by matlough, 20 Jul 2010.
  1. matlough
    matlough What's a Dremel?
    20 Jul 2010
    Just about to order a 5870 1gb and I spotted a 2GB 5870 EYEFINITY 6 for the same price!
    Are there any negatives to having this over the 1GB standard 5870?
    BTW I'm only using 1 monitor at the moment
  2. klutch4891
    klutch4891 What's a Dremel?
    4 Feb 2008
    I can't think of any (except maybe extra heat/noise from cooling the other gig of memory). If they're the same price you might as well go for it.
  3. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  4. klutch4891
    4 Feb 2008
    There isn't much point except for a few FPS with increased AA; but for the same price you might as well. And it comes with either 3 or 4 adapters. 2xDVI, 1xHDMI and something else if I remember correctly. But you can only use 2 adapters at once (the other 4 ports have to be Displayport).
  5. robots
    robots What's a Dremel?
    27 May 2010
    Are the clock speeds the same? In most games, the extra gig of ram will make very little difference unless you game at enormous resolutions.
  6. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    Very true. Even then it's debatable.
  7. korhojoa
    korhojoa durr
    31 Oct 2003
    I don't see any downsides from having more monitor connections and more memory.
  8. roosauce
    12 Feb 2010
    True - it will be pretty much the same for now, aside from the connections. If it is the same price and you're happy with display port then I'd go for it simply for longevity.
  9. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    yeah definatley dont pass it up for the same money
  10. wyx087
    15 Aug 2007
    for the same price: buy it!
    more memory, included adaptors (if buying retail) for normal monitors, what could go wrong?
  11. robots
    27 May 2010
    But only if it's the same clock speed :p
