Overclocking 5950X Overclocking
Discussion in 'Hardware' started by neocleous, 10 Dec 2020.
  1. neocleous
    neocleous Minimodder
    12 Feb 2002
    Hi all,
    I've just built my machine got it all configured and I'm going through tuning it up. I am a bit of a newb when it comes to overlocking but I've educated myself as best I can but I seem to be hitting a brick wall.
    My build is as follows:
    AMD 5950X
    Asus Strix X570-I MiniITX board
    16GB Crucial Balistix BLE2K8G4D36BEEAK 3600 MHz 16-18-18
    Corsair TX850M 850W PSU
    Arctic Freezer II 280mm AIO
    I ran Prime95 on a 32 core blanaced stress test and I can see in Ryzen master that the EDC get pinned to 100% on the default out of the box settings I was hitting 4.5ish GHz then I set it to Precision boost overdrive which upped the limit of EDC which again it took to 100% of the new value and I was still hitting the same 4.5GHz???
    Have I missed something?
  2. neocleous
    12 Feb 2002
    I should also mention I am on the latest BIOS, the board wouldn't boot with my CPU until I updated it which was a massive hassle!
  3. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    All core vs single or few core clocks. 4.5GHz will probably its all core target for your power and temperature. If yourun prime95 on one or a few cores you'll see it boost higher. Welcome to modern CPU's, where clocks are just targets that dynamically try to get reached!
  4. neocleous
    12 Feb 2002
    I tried one thread in Prime95 and the CPU split it across 2/3 cores so I couldn't pin one core.
    I'm sure there is a better way to test this.
    The power budget wasn't maxed out and the temperature was well under control so I'm not sure that upping them would make any difference.
