My PCI wifi card (edimax 7727In) has two antenna connections, I have recently moved and now connect to a virgin media superhub 2 which has 120mb cable. The router and wifi card both support 5ghz 802.11n, I am looking to replace the antennas as they are two different types that I have fitted from other network cards in the past just to get it working. I can see some antennas that are advertised as being 5Ghz compatible, but they look alot like the 2.4 Ghz ones. Can anyone recommend an antenna specifically designed for 5Ghz? The wifi card is connected at 72mbps even when in front of the router, but very rarely approaches more than 2MB/s or so in real world tests.
