Other 5m surge protector?
Discussion in 'Hardware' started by silk186, 20 Jan 2019.
  1. silk186
    silk186 Derp
    1 Dec 2014
    I've set up my desktop computer on the dining table, with no outlet near me.
    I require a lead that is 5m long. I can't find any suitable surge protector that is longer than 2m.
    Should I daisy chain it with another power bar or find a single outlet lead?
    Currently, I'm using a 5m power bar with no surge protection.
  2. TheMadDutchDude
    23 Aug 2013
    Just plug it into an extension lead.
  3. Dr. Coin
    Dr. Coin Well-Known Member
    13 Sep 2013
    Seconded
  4. thetech1
    thetech1 New Member
    17 Jan 2019
    Thirded!
  5. wolfticket
    19 Apr 2008
    Assuming UK, daisy chaining shouldn't be a problem as long as you don't get silly with cable lengths and respect the 13A/≈3kW total limit per wall socket.
    5M and longer surge protected extension leads are very common though, unless the point is that you rather work something out with buying something?
  6. silk186
    silk186 Derp
    1 Dec 2014
    For some reason, I wasn't finding them before. I would prefer to buy something new than daisy chain unless necessary. I think that issue is that I wasn't seeing any from brands I recognise. Belkin are almost all 2m with one 3m. It also needs 6 plugs, which seems to be '6 gang' in the UK. They are pretty much all made by pro elec on Amazon and Connekt on eBay. None of screwfix. They don't list any specs, level of surge protection or guarantee.
    I will have two surge protectors plugged into the same outlet but they won't have anything too crazy plugged in, mostly my computer and TV.
  7. wolfticket
    19 Apr 2008
    Masterplug are pretty reputable as far as I know, and they have a decent selection of lengths and sockets. There's something to be said for buying from well known high street retailers or supermarkets as well, as they'll probably feel a degree of liability for the products they sell, in the way Amazon for some reason doesn't :happy:
  8. silk186
    silk186 Derp
    1 Dec 2014
    Argos sells one model that is 5m 6 gang. It isn't even listed on the masterplug website.
  9. GeorgeK
    18 Sep 2010
