Electronics 5V Adjustible Universal V-Dimm Mod.
Discussion in 'Modding' started by Tulatin, 14 Oct 2004.
  1. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Here's the idea - a potentometer connected to ANY 5v source at one end and VCC on the dimm banks at the other. As you turn a potentometer attached to a small circuit, the voltage counter shows your voltage, then you hit a switch to set your dimm voltage. The device remembers dimm voltage between boots. It will be universal because all boards use VCC, can be placed in the front of a case to be used on the fly, and best of all is completely bios and OS independant. Anybody got any ideas how we can do this?
    Edit:
    Other side notes: a circuit to kneecap voltage at a certain level (say 5v) would be helpful, and the circuit should allow from 0-5V adjustability.
  2. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    I think some of the more "extreme" overclockers do this already. I saw a forum post, on another site, of a person building a voltage feeder for his graphics card - he had two pots, one for the GPU and one for the RAM.
    For the switch, building something to keep track of it digitally will be arduous, instead, a DIP switch can be put in place to allow different settings of the voltages. One for BIOS control, another for a voltage setting that is not dictated by the BIOS and so on.
  3. Tulatin
    16 Oct 2003
    would work, but there would have to be a set of resistors onboard for each dip that is switched... as to the idea, this is based on the universal 3.3V mod already. It just takes it a step further.
  4. Xiachunyi
    3 Nov 2003
    Ah I get it now.
    Would it be something like this?
    Of course without your memory implementation.
  5. Tulatin
    16 Oct 2003
    sort of but no. this involves tricking the controller. The mod i'm talking about involves tricking the ram itself.
  6. theshadow27
    theshadow27 What's a Dremel?
    23 Sep 2004
    the best way to do this is w/o a analouge pot, but ratehr with a rotory optical encoder and a PIC w/A-D, or better yet, with a digital POT chip. you could easly drive the led voltage display, and there are rotory encoders with built-in buttons so you could set and adust with just one control
