5v Line hovers @ 4.10- is that to low?
Discussion in 'Hardware' started by Phrozenpenguin, 9 May 2002.
  1. GJUK
    GJUK What's a Dremel?
    10 Apr 2002
    imho, i think it is a largeish risk, i mean its hard to say, you might be fine for 20 yrs !
    however that plastic has got MIGHTY hot mate, dont risk it. rma the mobo and chop out the psu man. PRONTO
    -again mho.
    Jono :)
  2. Phrozenpenguin
    Phrozenpenguin What's a Dremel?
    11 Dec 2001
    Thanks for the advice, but (foolishly) i am going to keep using them, for the moment anyway. I may see if i can find the mobo recipt tho...just in case :p
    Still no ideas on what actually caused the probs?
  3. GJUK
    10 Apr 2002
    *BOOM* :D
    dogeh connection = spark = burt pastic ?
    surge thro the mains?
    could be 10000000000 things :(
    least it aint dead :)
  4. Angel_of_Death
    Angel_of_Death What's a Dremel?
    9 Apr 2002
    my +5.00v line is at 4.97v is that ok? I'm not having any problems but i'd just like to know.
    Thanks
    AoD
  5. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    yep thats fine, anythin above 4.8 should be fine...
  6. Phrozenpenguin
    11 Dec 2001
    OK. SO ive been thinking - its only my 5V rail that is low, and only a couple of connectors look borked. A little look later, the 2 burnt connectors are the 5v connectors to the mobo (i think) so thats where the prob is i think. Maybe if i clean the mobo pins up, because theyre not letting enought through or sumamt?
