Graphics 6 pin adapter for a 460gtx . . . . .
Discussion in 'Tech Support' started by howeburn, 17 Dec 2012.
  1. howeburn
    howeburn What's a Dremel?
    17 Dec 2012
    I need two 6 pin adapters for a 460gtx and i've found several molex to six pin adapters but when i look at the the six pin connection only five of the pins have contacts in them . . three at the top and the botton right and left . . . . . . is this the correct configuration or should all the pins be filled ?
  2. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    That's how my adapter is laid out. The adapter came with my gtx 460.
  3. Snakko
    Snakko exterminate
    13 Dec 2009
    The official specification says that it shouldn't, but you can find cables with all the 6 pins fitted.
    The 2nd pin is called NC (not connected), some manufacturers add a +12v line on it just to fill it, but on the card connector it isn't used at all.
    The other two pins carry a +12v/8A line each, pin 4 and 6 are GND, and pin 5 is used for sensing/GND.
    So, it doesn't matter which kind of cable you get (with 5 or 6 pins), it'll work anyway :)
