Build Advice 600-700 new gaming system advice
Discussion in 'Hardware' started by saemilin, 5 Apr 2011.
  1. saemilin
    saemilin What's a Dremel?
    4 Apr 2011
    So I've been abroad for 2 years hunching over a netbook. Now I'm back and I really need a good computer that will last me.
    Budget: 600-700
    Main uses of intended build: gaming+work
    Will you be overclocking: yes/no (delete as required)
    YES, I want to try. After reading about multipliers and what not, I'll try to find a guide somewhere about it...It's supposed to be more simple now right?
    This is what I have right now:
    antec true power 650 psu (2009)
    500gb samsung hd (2009)
    dell 19 inch monitor (2005...kkk)
    keyboard, mouse, sound ok.
    This is on my shopping list... What do you think?
    Cost Item
    160 I5 2500k 3.3 oem
    120 Asus p8p67
    200 MSI gtx 560 Ti Frozr II 1gb
    40 Thermotake Frio cooler
    40 Corsair xms3 1600 4GB
    75 Windows 7 Home
    40 Antec 100 case...
    total= 675
    +additional 1tb hd= 715 ish...
    1) do you think this will all fit into the antec 100 ok?
    2) I just plan on getting the cpu to 4.5... will I need extra fans?
    3) I'm willing to spend a little money to future proof my PC a little. Should I spend a little more on a better case or is that fine?
    4) is the gtx560 too much?
    ...I actually have a sapphire HD 3850 from 2009...kk...
    5) is the RAM I've chosen good enough?
    6) what do you guys think about my selections? I've based everything off 2 days of internet research...
  2. chrismarkham1982
    chrismarkham1982 Multimodder
    1 Apr 2010
    thats a good system that will all fit into that case, the 560 will be major overkill for the 19" monitor but will be good for a long while yet in terms of longevity so id stick with it, fan wise stick with a front intake and rear exhaust and keep an eye on temps and then add more fans as needed, ram is absolutely fine, the case is fine but if you are willing to spend a bit then get yourself a cm690 or if you like sleek smart looking cases have a look at the fractal design define r3
    edit: sell the amd card, wont get much but its a few quid extra to buy a few beers and a curry while your benching your new machine:thumb:
  3. Dae314
    Dae314 What's a Dremel?
    3 Sep 2010
    That build looks fine. You will probably be just fine with everything as you have it. Now the next thing you need to do when you've got some extra quid on you is to get a 24" or so monitor.
    Don't worry too much about your memory for sandy bridge. You overclock sandy bridge through the multiplier so memory speed no longer affects your speed cap as strongly as it did when you overclocked through the FSB. Case is usually fine as long as everything fits and you're happy with how it looks.
  4. murraynt
    murraynt Modder
    6 Jun 2009
    You can't get much better really.
    If you want to go SLi in the future look at the Pro version.
    Personally I would go for a more expensive case. After all 700 pounds of hardware needs a good home.
    Have a look at the cases mentioned above/HAf X/ Xigmatek Utgard if you like that style
    What HDD are you going for? I would recommend the Samsung F3 1tb. Never had a problem with the F1/F3 HDDs
  5. saemilin
    4 Apr 2011
    Thanks guys, if I want to cut costs in some areas, where would I start?
    What cheaper graphics card would you recommend?
  6. murraynt
    murraynt Modder
    6 Jun 2009
    First thing I would do is go for is the -m version of your board.
    Second would be to drop the HSF down to a Coolermaster 212 Hyper Plus (Which would of been enough anyways)
    make sure to have a look on scans today only section.
    If you have to do futher cuts after that The GFX would have to be cut down to a 460GTX while will be a fairly large hit.
    Or else get your self a 5870
  7. The Monk
    The Monk Minimodder
    15 Dec 2010
    This is currently on a one day special for £180 at scan so if you bought that today you could save yourself £20 OR use the £20 to get a slightly better case :thumb:. Personally I would get a slightly better case but that's just my humble opinion
  8. murraynt
    murraynt Modder
    6 Jun 2009
    Indeed.
    Also if you are a student you can get student edition for half the price.
  9. saemilin
    4 Apr 2011
    kk. im using all your advice! i ditched the frio for the tranquillo...
    I missed the gpu in the todays section so that's another 10 pounds saved...
    and did you mean get the msi version of the mother board?
  10. saemilin
    4 Apr 2011
    Whats the difference between the m version of the board and the one I've selected? pros/cons?
  11. The Monk
    The Monk Minimodder
    15 Dec 2010
    The M version is Micro ATX meaning it's smaller than a standard ATX motherboard. With the reduction in size you lose some functionality.
    eg
    3 PCI slots on the none M and 0 PCI slots on the M version.
    Bluetooth on the none M and no bluetooth on the M version.
    4 sata 6Gb/s on the none M and 3 sata6Gb/s on the M version.
    2 USB 3.0 Headers on the none M and 0 on the M version.
    Hope that clears it up for you
  12. murraynt
    murraynt Modder
    6 Jun 2009
    The coolermaster is even cheaper and cools just as well.
    Although isn't as nice to look at.
  13. asteldian
    asteldian Minimodder
    13 Jan 2011
    Every other day a GTX 560 is on offer so just keep on looking. With free delivery (due to having over 20 posts) you should be able to cut costs without cutting quality of your build.
    You can usually save £20 or so with an i5 2500K and Asus Pro board often sold together.
    If you need to save money though, you have a great 500gb HDD already, why not wait before buying another HDD. Personally I have never come close to filling a 500gb HDD, but then I only game.
  14. Cruelinios
    Cruelinios EvE Addict
    21 Jan 2002
  15. Marine-RX179
    Marine-RX179 What's a Dremel?
    24 May 2010
    I'd swap out the Thermotake Frio cooler for something quieter. SandyBridge CPU doesn't run as hot as previous gens CPU anyway.
