Notebooks 600 dollars laptop
Discussion in 'Hardware' started by grritsshawn, 12 Feb 2011.
  1. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    Okay well i want a laptop for 600 bucks i have found an
    HP ProBook 4520s with a core i3 2.4ghz cpu and a 320gb hard drive with 2gb of ram and i can get 8gb of ram for a total of 570 or get another 2gb stick and a 500gb hard drive for 570
    Anyone other laptops?
    Main use
    Playing runescape
    watching movies and shows
    3d modeling a little here and there
    web
    I was thinking if i could find a good laptop cheaper then i can get an A-pad for 150 so about 400-600 dollars im willing to spend i mean the cheaper the better i will even do used new referbed idc i will even do fleabay!
  2. thelaw
    thelaw What's a Dremel?
    10 Sep 2010
    What graphics card/dedicated graphics chip does it have?
    Reading that spec it does not sound like it will play any games other than off facebook/java ones..
    http://www.pcadvisor.co.uk/reviews/index.cfm?reviewid=3224016
    The above review describes it as a business laptop with a intel onboard GMA graphics...so you may struggle gaming wise here....you need to be careful when selecting a laptop especially if you have gaming in mind, i made that mistake buying top of the range laptop 4/5 years ago not realising it came with intergrated graphics meaning anything that game that had a hint of 3D i could not touch no matter how good the other specs of it were CPU/RAM wise...
    Budget wise the best i could see with a dedicated ATI Mobility RadeonHD4250 graphics card was this one from dell for $530.
    http://www.dell.com/us/p/inspiron-15-m5030/pd?oc=dndohv1&model_id=inspiron-15-m5030
  3. grritsshawn
    20 Apr 2009
    Well thats what runescape is its a java based game been playing it for years and mayb mind craft right now im using an old Toshiba haha
  4. thelaw
    10 Sep 2010
    Well if your not planning to play anything else that is 3D intensive really then it should be fine choosing one that does not have a dedicated graphics card and the one you are looking at should be fine.:)
  5. grritsshawn
    20 Apr 2009
    i was thinking i do very little 3d modeling but alot of downloading should 4gb of ram b good or should i go for 8??
  6. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    I would not waste a dime on a HP laptop. They are rubbish laptops.
    I was debating myself between an Acer and a Toshiba. Mainly these two models.
    Acer
    Toshiba
    I went with the Acer because I wanted something lite and small. I have not received it yet, so if its not what I am looking for I am going to get the Toshiba instead and give that a go. Buy and try I say! :D
  7. grritsshawn
    20 Apr 2009
    ya but i want something fast and 600 shipped is all i got
  8. MSHunter
    MSHunter Minimodder
    24 Apr 2009
  9. thelaw
    10 Sep 2010
    As his location of his profile states "buffalo ny" and he priced in $ should be a dead giveaway
  10. grritsshawn
    20 Apr 2009
    still not sure still on the hp probook
  11. outlawaol
    18 Jul 2007
    Didnt realize you wanted total cost to be $600+ all taxes and s/h.
    So here is a Lenovo that should add up to around $600 total. I was debating on this one as well.
    I figured around a 5.5% tax and around $7-9 for shipping. Also if you have any issue you can return it to any Walmart store around the area (if one is close to you can have it shipped to that store for free too).
