Storage 60gb ssd, what should I do with it?
Discussion in 'Hardware' started by Brooksie, 13 Oct 2012.
  1. Brooksie
    Brooksie What's a Dremel?
    30 Aug 2011
    Right so I picked up a bargain Kingston 60GB V+200 SSD from ebuyer for £30 the other day. Now I have it I am not sure what to do with it. I want to use it to speed up windows on my desktop. Do you think it's big enough to install Windows and BF3 on?
    If not can I install it as an extra drive and somehow use the speed of it to speed up windows? ie let windows put the swap file on it?
    Open to suggestions :D
  2. atanum141
    22 Jul 2004
    More than enough for an OS with some apps and the odd few games.
  3. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    I use to have Window's 7 Ultimate 64Bit, all my apps such as Nero etc installed on it and 2 games.
    You should be fine with a 60Gb for now.
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Should be enough for OS and BF3 and some other apps. I would use it as such. But, you have z68 board so you do have the option to use it as a cache drive too with intel SRT if you would rather go that way.
  5. scott_chegg
    scott_chegg Minimodder
    16 Feb 2010
    This Cheesecake.
  6. jinq-sea
    15 Oct 2012
    60Gb should see you right - I ran a 64Gb SSD for ages, and just had to be a bit selective about what I had installed at any one time. Enjoy the speed boost!
  7. JamesRC
    JamesRC Minimodder
    5 Oct 2012
    An SSD is a fantastic upgrade - I should have picked up this drive for my new media centre but I hesitated, it was such a bargain at £30.
    60Gb will be fine for the OS plus a couple of games. BF3 is huge though - you'll likely want a 120Gb or 240Gb drive in the near future!
