Linux 64-Bit Linux Distros?
Discussion in 'Software' started by arrowswake, 18 Oct 2004.
  1. arrowswake
    arrowswake What's a Dremel?
    3 May 2004
    I gave up on finding a 64-bit distribution for Mandrake... I have a few questions now...
    1) I read somewhere that 32-bit distributions work fine on 64-bit Cpu's... Is this true? Is there diminished performance if so?
    2) What other distros have 64 bit versions? I know that SuSe 9.1 has a 64-bit distro, but the only mirrors didn't have ISO's... How would I get it to be a boot CD (or dvd) if I had to download all the files individually?
    Thanks in advance.
  2. woodshop
    woodshop UnSeenly
    14 Oct 2003
    there is a 64 bit fedora.
    and
    of coure there is Gentoo
  3. Bruno_me
    Bruno_me Fake-ad‎min
    30 Mar 2003
    yes, that's true, just like all the people that run 32-bit windows on a 64-bit cpu*
    (*a64, as it has both 32-bit and 64-bit extensions)
    you could always do fedora
  4. arrowswake
    3 May 2004
    I have Fedora, and it won't install. It hangs at:
    Running install...
    Running /sbit/loader
    I've tried both the DVD and CD isos, and both of my drives. I searched google and found that a lot of people have had this problem, but no solutions to it.
    And I've heard that Gentoo isn't very user-friendly. I used Mandrake 7 a little bit a while ago, but that's my only experience so far...
  5. Bruno_me
    30 Mar 2003
    how long did you let it sit at starting /sbin/loader?
    anaconda usually takes a little while to start
  6. arrowswake
    3 May 2004
    I let it sit for like 4-5 minutes. On top of that, I could type and it would display on the screen. I couldn't perform any commands or anything, I could just type and it would display...
  7. Bruno_me
    30 Mar 2003
    well, that's hardware incompatability
    so I guess fedora won't work right :D
    anyway, if you rtfm, gentoo can be very user friendly, I've heard portage isn't that great, but it can be very, fast, and useful
  8. woodshop
    woodshop UnSeenly
    14 Oct 2003
    the initial instal is not to user friendly in Gentoo.
    But it is very well documented.
    and after you get it installed it's as simple as.
    emerge xxx
    with xxx what you and to install.
    Te rest is fully autiomated
  9. arrowswake
    3 May 2004
    Okay, I'll try that then. I read that it wasn't user-friendly, so I didn't even bother looking into it anymore... Hopefully this will work, heh.
  10. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    The main difficulty with Gentoo is that you have to compile everything, but
    you do end up with an OS that is tailor-made for your exact system.
  11. Uncle Psychosis
    Uncle Psychosis Classically Trained
    27 Jul 2003
    Rubbish, Portage is the dogs danglies! It's incredibly simple to use, incredibly powerful, and you won't get stuck in dependancy hell like with rpms or even apt.
    If there were only one reason to use Gentoo it's Portage...
    Sam
  12. Skylined
    Skylined Minimodder
    3 May 2003
    SuSE 9.1 isn't free, that's why you cannot download it.
    All you can get it's their Live CD to give SuSE a try. ;)
  13. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Of course, all this doesn't matter if you want to use a recent ATI video card, as they don't have 64-bit linux drivers yet :wallbash:
  14. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    It was free when first installed it ~6months ago.
    And I've just checked. It still is :p
  15. Uncle Psychosis
    27 Jul 2003
