Windows 64 bit windows disks wont read in my PC (7 AND 8!!)
Discussion in 'Software' started by dave_c, 2 Mar 2013.
  1. dave_c
    dave_c Minimodder
    31 Jul 2009
    When i bought windows 7 the 64bit disk wouldn't work (32bit was fine) it just revved up then down continuously in the drive. So i downloaded an 'ahem' copy and then used the proper authentication code which i got with the purchased copy.
    Thought this was a fluke and i had got a faulty copy but just got home and exact same issue with the 64bit windows 8 (haven't tried the 32bit one yet).
    Never had issues with any other disks only ever 64bit windows OS disks. anyone know what this could be?
  2. Deders
    Deders Modder
    14 Nov 2010
    Did you try burning the DVD at a low speed?
  3. GoodBytes
    20 Jan 2007
    Is it the same optical drive? I recall back in Vista days, some optical drives had to get a firmware update.. or just changed, in order to recognize 64-bit install.
    Personally, I recommend to use a USB flash drive. It will be faster (assuming you have decent flash drive), and your BIOS/UEFI should see it as normal drive. I got Windows 8 installed in 6min using a USB flash drive.
  4. dave_c
    dave_c Minimodder
    31 Jul 2009
    sorry what i meant was the burned disks work fine. its JUST the official disks that i have issues with.
    i don't like using burned disks however as people may have put additional unwanted software onto them. i.e. spyware.
    and yes it is the same optical drive, i considered the possibility that it was faulty but then it reads EVERYTHING else perfectly well, i don't understand why a 64bit OS would be written so dramatically differently from a 32bit OS that it wouldn't even read it. that may be more a sign of my ignorance than of bad-logic though :)
    i agree with using a USB pen but i cant get the data off the disk to put onto the USB pen, and if i download the OS then I'm back to the same problem (i.e. possible questionable third party software)
  5. GoodBytes
    20 Jan 2007
    Some optical drive are made crappy, where it assumes that you are using a 32-bit OS, and that all your content that put are 32-bit, so it only reads 32-bit chunks at a time and the CPU goes, when you have 64-bit content on the disk: "WTF?! It's part of an instruction?!.... Oh well I guess I can't read the disk"
