Graphics 670 v 580
Discussion in 'Hardware' started by oblivion181, 21 Jul 2012.
  1. oblivion181
    oblivion181 What's a Dremel?
    20 Dec 2009
    Ok, so the pricing is about the same depending on company, so for high demand games which is better on a 2560x1440 resolution. A 2GB 670, or a 1.5GB 580.
    Thanks for any input
  2. wyx087
    15 Aug 2007
    unless you are buying 2nd hand where 580 can be had for just over £200, go for 670 without a doubt.
  3. oblivion181
    20 Dec 2009
    Thanks, stupid question though I suppose really.
  4. Kronos
    Kronos Multimodder
    6 Nov 2009
  5. GoodBytes
    20 Jan 2007
    I like the first link, Kronos. Beside Wattage, the other stats mean absolutely nothing.
    670 looses everywhere, yet it more powerful than the 580.
  6. rollo
    rollo Modder
    16 May 2008
    670 is faster in games worse in cuda simple enough
  7. David
    7 Apr 2009
    For gaming? 670 without a doubt.
    clicky
    Much lower power consumption too.
    N17 dizzi likes this.
  8. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Never backwards always forward. 670 for sure
  9. allanparker
    allanparker What's a Dremel?
    15 Jul 2012
    The GeForce GTX 580 features a GPU core clock speed of 772 MHz, and the 1536 MB of GDDR5 RAM runs at 1002 MHz through a 384-bit bus. It also features 512 SPUs, 64 Texture Address Units, and 48 Raster Operation Units.
    Compare that to the Geforce GTX 670, which has a GPU core clock speed of 915 MHz, and 2048 MB of GDDR5 memory running at 1500 MHz through a 256-bit bus. It also is comprised of 1344 Stream Processors, 112 TAUs, and 32 ROPs.
