CPU 6700K high frequency temperature variation.
Discussion in 'Tech Support' started by TheRoyalDuck, 24 Aug 2016.
  1. TheRoyalDuck
    TheRoyalDuck New Member
    24 Aug 2016
  2. Yadda
    Yadda Well-Known Member
    25 Jul 2003
    It's normal for the CPU temperature to ramp up/down very quickly when the CPU load changes. What cooler are you using?
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    What Yadda said, 70°C is a pretty good temperature under load.
  4. danielleil
    danielleil Can't stop spending...
    20 Aug 2009
    what volts / frequency are you running?
  5. NeiltheDruid
    NeiltheDruid Member
    20 May 2009
    Looks pretty normal to me. In the second pic, you can see where the load is applied, the temperature shoots up, the PWM detects and responds, bringing the curve down, then holding the CPU a couple of degrees either side of 57.5. Pretty stable and healthy temperature under load.
