Graphics 6800 , Equivalent
Discussion in 'Hardware' started by WaLLaWaLLa92, 22 Aug 2005.
  1. WaLLaWaLLa92
    WaLLaWaLLa92 What's a Dremel?
    27 Jul 2005
    Ok well ive been looking at the base 128mb 6800 , i think its the vanilla version which apparently is easier to clock and has 12 Pipelines and 5 Vertex Shaders enabled instead of the 16 Pipelines and the 6 Vertex Shaders of the GT and Ultra versions , i was also looking at the x800 base 128mb version , what do you think id all be best to do?? , thnx :D
  2. koola
    koola Minimodder
    11 Jul 2004
    X800XL is a great card!
    Full 16 pipes, but lower clocks.
  3. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    However, in just a short google trip you can learn how to unlock 16x6 on the 6800. However, if you want out of the box service, get a GT or X800XL.
  4. TMM
    TMM Modder
    12 Jan 2004
    X800XTs are cheaper then X800XLs over here - not sure about where you are but i'd check it out.
    I'd get a 6800(vanilla) and unlock (if you can) + overclock.
  5. chemo
    chemo True Jungle Brother
    20 Feb 2005
    unlocking the 6800 is risky as not always works out.
    x800xt is the best card out of the ati ones if its the cheapest too, its a no brainer
  6. WaLLaWaLLa92
    27 Jul 2005
  7. P2D
    P2D 99.999% Pure Spam!
    26 Mar 2004
    I bought the Inno3d 6800 and unlocked it, runs awesomely and i get some insane clocks from it (Much higher than average acording to various sources) id recommend anyday
  8. BjD
    BjD What's a Dremel?
    10 Apr 2003
    Got that a couple of weeks ago, not attempted to unlock anything yet as its fairly r0x0ring by box as it is :lol: I want to get some improved cooling first anyway, be interesting to see how yours goes.
  9. olv
    olv he's so bright
    23 Sep 2002
    I just got a 6800LE which is 8x4 default. unlocked to 12x6, 16 pipelines gave artifacts, and running 400mhz core and 900mhz memory atm. excellent card for the price imo.
  10. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    you have to remember that if you're going to unlock it you definately want aftermarket cooling. I suggest the Zalman Vga 700CU i think.
