Modding 6800GT bending???
Discussion in 'Modding' started by beastnburger, 24 Nov 2005.
  1. beastnburger
    beastnburger What's a Dremel?
    18 Aug 2004
    Hello, i am almost finished with the watercooling of my pc, but after i installed the NV-68 waterblock on my BFG 6800 GT OC and put it in the AGP slot on my mobo, it seems as if it's bending. Here's a pic:
    Is this even a problem? Im just worried it's adding stress to the mobo or the card.
    Thanks
  2. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    Several people have noted this with the NV68 and NV70 blocks. Just use a small support such as an acrylic rod to take the load either between the corner of the card and the bottom of the case or between the block and the base of your case.
  3. Jaxx
    Jaxx What's a Dremel?
    7 Apr 2004
    If the block was 7 kg's or so I would suggest a support of some sorts, like Awoken suggested. But The block won't snap the card off the mobo at all. All circuit boards are durable for that kind of abuse
  4. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    You could always pull a Nexxo too (see project Metaversa).
  5. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Do similar to what pookeyhead did. Acrylic rod. (Old cathode tube I believe)
    Better safe than sorry ;)
  6. Ener
    Ener What's a Dremel?
    17 Oct 2005
    that arylic rod sounds like a great idea :D
  7. clocker
    clocker Shovel Ready
    21 Dec 2003
    Aluminum (in this case 3/8") rod works well too, is easy to drill/tap and readily available at home improvement/hardware stores...
  8. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    or just let it bend the metarinka way, My old geforce 4 bent a considerable amount, both like yours and its also bent sideways out of the slot, haven't' noticed any problem from it
  9. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Yeah, I agree, my 6600GT's bending more than that and it's perfectly stable. Circuit boards are made of tough stuff, they're now using it to scale knives.
    Nice fix though, it does look a lot better :thumb:
  10. Nexxo
    23 Oct 2001
    Heheheh... I like how certain mods or solutions get associated with people...
    Almost like Martial art moves: "Way of the furious mod"... "Path of the swift Overclock" :D
  11. Lemmingzappa
    Lemmingzappa What's a Dremel?
    8 Nov 2004
    does anyone know if you get this kind of card abuse using maze 4's ?
  12. 1e8o
    1e8o What's a Dremel?
    13 Oct 2005
    You just have too support it in the corner.
    with a trianangle in the corner with a "geleider" that supports the card.
