Graphics 6800GT bios check
Discussion in 'Hardware' started by cfuk, 18 Apr 2005.
  1. cfuk
    cfuk What's a Dremel?
    9 Jul 2004
    I'm having probelms with my 2 XFX 6800 GT's running in sli when i boot up. They are both the same card and rev 1. Is there away i can check if they both have the same bios? also if they don't how do i go about putting the same bios on both cards?
  2. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    Boot with just a single card installed and SLI disabled then check the bios. Repeat for the other card. Nvidia has a flash utility and there will probably be one (& a selection of bios' [whats the plural for bios?]) on the support section of your gfx card manufacturer :thumb:
  3. cfuk
    9 Jul 2004
    i've just checked on the XFX forums and can't see any bios updates :(
    does anyone know where i can get one from and the best flash utility?
  4. Awoken
    3 Mar 2004
  5. Tim S
    Tim S OG
    8 Nov 2001
    if anything goes wrong, just find an old PCI card and flash it back to the original BIOS. ;)
