690 GTX Settings
Discussion in 'Gigabyte' started by Blarte, 6 Aug 2012.
  1. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    Dear Gigabyte..
    Proud owner of a new 690 GTX ..
    Some issues regarding the settings though. It keeps on clocking down and I am getting worse performance than when I had the two 580's in sli on Skyrim etc ..
    Its sat in a asus gene z68 board with 4.4oc on a 2600k cpu. 8gb of ram
    When testing the card on evga's gpu precison x .. it initially starts off at base clock and then immediately clocks down to around a third of its potential (ie getting shi**y results)
    Can you suggest settings please.
    Cheers in advance
    Dave
  2. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    Try enabling maximum performance in the power setting for the specific application via the Nvidia control panel
    Sent from my GT-I9300 using Tapatalk 2
  3. Blarte
    15 Jul 2008
    will try that when I get home Lysaer..
  4. Blarte
    15 Jul 2008
    worked a little better ..stuck on base clock though.
  5. Blarte
    15 Jul 2008
    eventually RMA's this card and those nice chaps at Gigabyte are replacing - must have been a duffer. Thanks
