can any one please tell me or show witch order the psu wires are placed in this plug as i only have the old aux thing plug and want to change it over to the new pci-e plug
A diagram can be found here. The wire colours may be different but the values should always be the same. It really should be on it's own 12v rail too, IIRC.
looking at that pic its great info thanks. The problem i have it that the psu did not come with the new pci-e plug. The psu is a atx1 unit and came with the very old slim 6 pin aux plug
If you're not using the 4 pin P4 connector you could rewire that, if your PSU has plenty of capacity.
Picture looks like it's from Ebuyer to me... please don't say it's their £10 "500W" supply. Do not try to run a high-power video card on that unless you're feeling lucky.
It really depends what's in your system. Anything quality (Enermax, Antec, Tagan, Hiper, Seasonic) of about 400 watts should cope with most systems. Post your specs here so we can take a look
i have amd64 3000 200 gig sata hd dvdrw 6 80mm case fans msi neo 4 plat 1 gig of 400ddr ati x700 pci-e 256mb
