Motherboards 7 Beeps when trying to post. AMI bios
Discussion in 'Tech Support' started by confusis, 1 Apr 2010.
  1. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Hi,
    Building my socket 603 Xeon board and on power up it beeps at me! nuuuuuuuuuuu............
    Error is as follows (copypasta from all mighty google):
    seven short "Virtual Mode Exception error"
    What the hell is that and how can I fix it? Should I just reseat the CPUs/swap sockets?
    Board is a Gigabyte 8ipdxr
    CPU Dual Xeon socket 603 2.4ghz
    4x 512mb DDR RAM
    Currently no drives attached
  2. confusis
    5 Jan 2006
    Would this be due to insufficient power? The board has a 8 pin and 4 pin plug for power whereas the psu only has the 4 pin. can't see anything in the manual to suggest i HAVE to use both though.
    PSU is only a 320W but the online PSU Calc reccomends at least 211 watt for the current setup
  3. confusis
    5 Jan 2006
    Uh-oh. If i remove the memory and test like that it beeps 6 times.
    "Six beeps means that there has been an 8042 Gate A20 test error. This beep code is usually caused by an expansion card that has failed or the motherboard that is no longer working."
    no expansion cards. I bought a dead board :X
    Might buy a single xeon to test in case these cpus are toast
    However with no cpu and no memory I get no beeps at all :?
  4. DK63
    DK63 Resident magpie
    8 Sep 2009
    With no cpu and memory, nothing works! I'd try it with only the cpu and memory installed. No expansion cards, hdd or optical drive. See what happens then.
  5. confusis
    5 Jan 2006
    Ummm I'm sure I said nothing else was plugged in. No drives, no cards, just psu, cpu and ram
    Any combination of 1 or 2 cpus and memory gets 7 beeps on boot.
  6. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    who is the manufacturer, and what is the model number of the board? If the error is really a Virtual Mode Exception error, that means the BIOS had problems putting the CPU into protected mode.
    If the 6 beeps is accurate, then it means the BIOS was not able to to enable the gate on the 20th address line which is a historic IBM PC thing that has been kept around for reverse compatibility.
    I find both of these errors hard to believe, I want to check them against a book I have at work.
    There are a couple reasons these beep code may not be accurate. The first is that the board manufacturer may have a license to the BIOS source and changed the beep codes on their own. Or the info Google lead you to is for a different BIOS version and it has been changed. In both cases, you will need to check the manual for the main board.
  7. confusis
    5 Jan 2006
    The board is a gigabyte 8ipdxr. The only manual I can find on the gigabyte website doesn't list post error codes. Odd thing is when I boot it the cpu fans don't spin! Maybe I do need to connect both the 8 pin and 4 pin aux power sockets.
    EDIT:
    Can anyone confirm if my power supply may be insufficient and therefore causing the problem? I don't want to rip the 500w out of this rig just to test it!
  8. confusis
    5 Jan 2006
    any ideas guys?
  9. Splynncryth
    31 Dec 2002
    Yes, you need to connect all your power connections. If I remember correctly, those Xeons use the Netburst architecture which was never known for being stingy with power.
    the lack of at least one 12 volt rail could be causing the CPUs to fault badly which is what the 7 beep error would indicate.
    confusis likes this.
  10. confusis
    5 Jan 2006
    Ah. Have a 8pin adapter coming very soon so should help. I just couldn't see in the manual that you had to use both 8 and 4 pin (they do the same job) so thought I'd get away with it. Adapter goes from 2x molex to 1x 8pin. Will use molex's off different lines from the PSU just to help out. I'm using my 400w server grade older atx jobby PSU. Adapter was shipped from the States on Saturday so should be here soonish.
    Yes the Xeons are Prestonia Netbursts. Claimed TDP is 65w but there are 2 of them..
    Thanks Splynncryth
  11. Splynncryth
    31 Dec 2002
    If the power layout is like later Intel boards, then the 4 pin should supply power to the chipset and the 8 pin powers the CPU.
    The need for the number of rails just cuts down on a single point of failure and reduces stress on any one rail. As long as a single rail can source the total combined current from separate rails, you should be OK. You might test with just 1 CPU after you get your adapter though. It is still possible that there is a CPU or board probelm.
  12. confusis
    5 Jan 2006
    Makes sense.
