Electronics 7 segment display
Discussion in 'Modding' started by kimolabu, 17 Dec 2004.
  1. kimolabu
    kimolabu What's a Dremel?
    17 Dec 2004
    I am a new-bie in this forum but it looks great.
    I have a problem with 7-segment displays. I need some suggestions about managing 20 7-segment displays in 5 rows and each row include 4 7-seg. displays. What will be the best solution for this problem.
    0.0.0.0. first row of 7-seg. diplay(include 4 digit)
    0.0.0.0. second row of 7-seg. diplay(include 4 digit)
    0.0.0.0. third row of 7-seg. diplay(include 4 digit)
    0.0.0.0. fourth row of 7-seg. diplay(include 4 digit)
    0.0.0.0. fifth row of 7-seg. diplay(include 4 digit)
    I appreciate any help
  2. nleahcim
    nleahcim What's a Dremel?
    22 Apr 2003
    How are you looking to control them? Computer? Microcontroller? other? Maxim does a number of useful display drivers.
  3. kimolabu
    17 Dec 2004
    I intent to use pic microcontroller (16f877 or similar ones). I also want to use minimum number of pins since i will need other pins for different purposes
  4. Mr.Nonflex
    Mr.Nonflex What's a Dremel?
    2 Jun 2004
    I should use 74hc595 shiftregisters for the anodes, use shiftregisters in combination with uln2803 to switch the kathodes.
    I am using this for my 14 segment hd44780 project.
    Use the apropriate resistors befor each segment. I sugest so hook up 8 displays max on each resistor, and multiplex them.
    if u do this, u do not need more than 3 io ports to drive them, as you can chain all the 595 registers. :thumb:
