Electronics 7-segment LED Clock
Discussion in 'Modding' started by Explicit, 27 Sep 2004.
  1. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    My latest find on eBay:
    PCB with logic and six 12mm Nu-Metric numitrons (labeled P/N 29-101 & P/N 29-103) for $10.00.
    Unfortunately one of the tubes is a '+-1' , therefore I'm missing one digit to make a 6-digit 24H-clock.
    The 7-segment tubes are identical to the Apollo DA-1300 numitrons, if somebody owns one and is willing to sell/trade it :naughty: ...
    CD :)
  2. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    Make a 12 hr clock, and use the + sign as a am/pm indicator...
    What are the logic chips on that board?
    Oh, BTW, on http://www.kdcs.be/en/savoirfaire.asp, under "In Web Development" Platform .NET is spelled "Plateform .NET"
    (my mother was an english major)
  3. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    Thanks for the spelling correction!
    The board contains 5x 7447 BCD-to-7-segment-decoders, 1x 7406 inverter/buffer to drive the +-1 tube, 6x 7475 4-bit latches, 1x 74121 MMV, 6 chips labeled N8285A, and 2 chips labeled N8H80A.
    Don't know what these N8285A and N8H80A chips are for as I couldn't find a datasheet for them...
    I traced the GND, logic +5V, common drive voltage for the numitrons (I used 5V too) and the 7447 lamptest connections on the terminal block on the board to test the display.
    There's also room for a 6th 7-segment digit + logic chips on the board but they aren't fitted.
    I'm not really fond of 12H-clocks with am/pm indicator (in Belgium we always use the 24H time display on digital clocks), therefore I hope to find a spare Apollo DA-1300 7-segment tube one day...
    CD :)
  4. mattthegamer463
    26 Nov 2004
    so, those tubes are like light bulbs, except the filament is bent into different shapes so they light up and form numbers? whats their life expectancy then? i would think they wouldnt last too long.
  5. Wolfe
    7 Sep 2003
    They last quite a while, as the filament is really underdriven (IIRC).
    Think about how bright they are in comparison to a normal light bulb.
  6. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    Datasheet states 100000hours @5V...
    CD :)
  7. eutronix
    eutronix What's a Dremel?
    28 Nov 2005
    Hi Turbokeu,
    We are trying to get our own large digit clock going, but we are having some trouble getting the display multiplexed properly. We are able to get everything but the first digit lit properly which has some leakage from other numbers in the clock. We've tried setting a blanking peroid, but it doesn't seem to have any effect. We've tested the circuit and have verified we have individual control of each digit, so this is purely a software problem. Is there any chance you could post a little piece of your clock code as it pertains to the multiplexing aspect?
    Thanks,
    Stu
  8. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    Sorry for the late reply...
    I will reply in several parts as the max length of a message is 10K characters.
    Here come the declarations:
    Code:
    ;* Program: LED-DCF-v25a.asm                                                   *
    ;* For PIC16F876 and 6x Common Anode 7-Segment LED displays                    *
    ;* DCF77 routines initially based on Yves Heilig's DCF77 routines              *
    ;* Added DD,MM,YY DCF77 decoding                                               *
    ;* Clock/Calendar routines based on Jaakko Ala-Paavola's Clock routines        *
    ;* DCF77 LED Clock                                                             *
    ;* Version 2.5a - 28/09/2005                                                   *
    ;*   TO DO:        *
    ;*   - Automatic Time/Date routine?                                            *
    ;	Xtal=4.096MHz
    ;	Timer0 Prescaler=8
    ;	ISR=every 2.0msec
    ;	Interrupt on Timer0 overflow
    	LIST	p=16F876 	; PIC16F876 is the target processor
    	#include "P16F876.INC"	; Include header file
    	RADIX		HEX
    	EXPAND
    	__CONFIG _CP_OFF & _WDT_OFF & _XT_OSC & _LVP_OFF & _BODEN_OFF & _PWRTE_ON
    ;*                              - Declarations -                               *
    ; DCF77 Variables
    SEC_DUR		EQU	0x30	; DCF second duration, used to test absence of 59th sec
    BIT_DUR		EQU	0x31	; DCF bit duration
    BIT_NBR		EQU	0x32	; DCF bit number (0 to 58)
    PARITY		EQU	0x33	; Even Parity check bit
    MINDCF		EQU	0x34	; DCF Minutes in packed BCD format: 10's,1's
    HOURDCF		EQU	0x35	; DCF Hours in packed BCD format: 10's,1's
    DAYDCF		EQU	0x36	; DCF Days in packed BCD format: 10's,1's
    MONTHDCF	EQU	0x37	; DCF Months in packed BCD format: 10's,1's
    YEARDCF		EQU	0x38	; DCF Years in packed BCD format: 10's,1's
    ; Flag bytes
    FLAG1		EQU	0x39	; 1st Flag byte
    FLAG2		EQU	0x3A	; 2nd Flag byte
    FLAG3		EQU	0x3B	; 3rd Flag byte
    FLAG4		EQU	0x3C	; 4th Flag byte
    ; BIN2BCD Conversion Variables
    BIN		EQU	0x3D	; Temp register for BIN to BCD conversion
    BIN1		EQU	0x3E	; Temp register for BIN to BCD conversion
    BIN10		EQU	0x3F	; Temp register for BIN to BCD conversion
    ; BCD Clock Variables for display output
    SEC1		EQU	0x40	; Contains 1's of Seconds
    SEC10		EQU	0x41	; Contains 10's of Seconds
    MIN1		EQU	0x42	; Contains 1's of Minutes
    MIN10		EQU	0x43	; Contains 10's of Minutes
    HOUR1		EQU	0x44	; Contains 1's of Hours
    HOUR10		EQU	0x45	; Contains 10's of Hours
    DAY1		EQU	0x46	; Contains 1's of Days
    DAY10		EQU	0x47	; Contains 10's of Days
    MONTH1		EQU	0x48	; Contains 1's of Months
    MONTH10		EQU	0x49	; Contains 10's of Minutes
    YEAR1		EQU	0x4A	; Contains 1's of Years
    YEAR10		EQU	0x4B	; Contains 10's of Years
    ;		EQU	0x4C	;
    LDR		EQU	0x4D	; Contains result from A/D conversion
    PWM		EQU	0x4E	; Value to put in CCPR1L register for PWM function
    ;		EQU	0x4F	;
    ; Display Variables
    D1		EQU	0x50	; Contains BCD value of Digit 1 to display (most right)
    D2		EQU	0x51	; Contains BCD value of Digit 2 to display
    D3		EQU	0x52	; Contains BCD value of Digit 3 to display
    D4		EQU	0x53	; Contains BCD value of Digit 4 to display
    D5		EQU	0x54	; Contains BCD value of Digit 5 to display
    D6		EQU	0x55	; Contains BCD value of Digit 6 to display (most left)
    DIGIT		EQU	0x59	; Holds digit number to display (1 to 6)
    ; Counter Variables
    CNT1		EQU	0x5A	; Counter for 0.5sec Beat timing delay
    CNT2		EQU	0x5B	; Counter for Scrolling Routine delay
    CNT3		EQU	0x5C	; Counter for Date display timing delay
    CNT4		EQU	0x5D	; Counter for hourly Gong timing delay
    CTR1		EQU	0x5E	; Delay counter for Main routine
    CTR2		EQU	0x5F	; Delay counter for Main routine
    ; Clock/Calendar Variables
    MSEC		EQU	0x60	; 4 millisecs counter (*XD=1sec)
    SEC		EQU	0x61	; 24H-Clock Seconds
    MIN		EQU	0x62	; 24H-Clock Minutes
    HOUR		EQU	0x63	; 24H-Clock Hours
    DAY		EQU	0x64	; Calendar Days
    MONTH		EQU	0x65	; Calendar Months
    YEAR		EQU	0x66	; Calendar Years
    ; Timer Variables
    TIME_ON_H	EQU	0x67	; Time ON Hours
    TIME_ON_M	EQU	0x68	; Time ON Minutes
    TIME_OFF_H	EQU	0x69	; Time OFF Hours
    TIME_OFF_M	EQU	0x6A	; Time OFF Minutes
    AUX1		EQU	0x6B	; Used for 16-bit comparisons
    AUX2		EQU	0x6C	; Used for 16-bit comparisons
    ;  Conversion Variables
    BCD		EQU	0x6D	; Temp storage for BCD to BIN conversion
    BCD1		EQU	0x6E	; Temp storage for BCD to BIN conversion
    BCD10		EQU	0x6F	; Temp storage for BCD to BIN conversion
    ; Common Variables
    W_TEMP		EQU	0x70	; W Register storage during Interrupt
    STATUS_TEMP	EQU	0x71	; STATUS Register storage during Interrupt
    PCLATH_TEMP	EQU	0x72	; PCLATH Register storage during Interrupt
    TEMP		EQU	0x73	; Temp storage
    OFFSET		EQU	0x74	; Temp storage for Table reads
    ; Constants (for 4.096MHZ XTAL)
    XD		EQU	D'250'	; Xtal divider = D'250' for 4.096MHz Xtal
    ; FLAG1 bits assignments
    M0		EQU	0	; Indicates start of new minute for Time Check
    S0		EQU	1	; Indicates start of new minute for DCF_OK
    BEATF		EQU	2	; Colon Beat indicator update flag (for 1Hz Beat delay)
    TIMERF		EQU 	3	; Time Check status flag (0=OFF, 1=ON)
    TDF		EQU	4	; Display Time/Date bit (0=Time, 1=Date)
    PBF		EQU	5	; Indicates Push button press
    TZ0F		EQU 	6	; Indicates Time Zone ; TZ1F/TZ0F=11=CET
    TZ1F		EQU	7	; Indicates Time Zone ; TZ1F/TZ0F=01=CET-1H
    						    ; TZ1F/TZ0F=10=CET+1H
    ; FLAG2 bits assignments
    ISR		EQU	0	; Flag for DCF77 and Clock update in ISR
    RXD		EQU	1	; Indicates reception of a DCF bit (0 or 1)
    DCF_BIT		EQU	2	; Value of actual received DCF bit
    S59		EQU	3	; Indicates missing 59th pulse of DCF timeframe
    CET		EQU	4	; CET Time Zone flag (0= not CET; 1= CET)
    DCF_ERR		EQU	5	; DCF Error flag (=0 when Startbit and Parity are OK)
    DCF_OK		EQU	6	; DCF frame OK status indicator flag
    DCF_ON		EQU	7	; Indicates presence of DCF signal (checked every sec)
    ; FLAG3 bits assignments
    MINF		EQU	0	; Indicates reception of DCF Minute bits
    HOURF		EQU	1	; Indicates reception of DCF Hour bits
    DAYF		EQU	2	; Indicates reception of DCF Day bits
    MONTHF		EQU	3	; Indicates reception of DCF Month bits
    YEARF		EQU	4	; Indicates reception of DCF Year bits
    DOWF		EQU	5	; Indicates reception of DCF DOW bits
    LYF		EQU	6	; Leap year flag
    SCROLL		EQU	7	; Indicates change of state of Pushbutton for Scroll routine
    ; FLAG4 bits assignments
    AUTOF		EQU	0	; Automatic Time/Date flag (0=ON, 1=OFF)
    GONGF		EQU	1	; Hourly Gong flag (1=ON, 0=OFF)
    ; PORTA assignments
    LDR_IN 		EQU	0	; AN0 bit: LDR Analog input
    TD		EQU	1	; RA1 bit: "Time/Date" Push Button input
    TZ0		EQU	2	; RA2 bit: "Time Zone0" Jumper input
    TZ1		EQU	3	; RA3 bit: "Time Zone1" Jumper input
    DCF_IN		EQU 	4	; RA4 bit: DCF77 signal input
    AUTOTD		EQU	5	; RA5 bit: Automatic Time/Date switch
    ; PORTB assignments
    RB0		EQU	0	; RB0 bit: 4543 D0 bit output
    RB1		EQU	1	; RB1 bit: 4543 D1 bit output
    RB2		EQU	2	; RB2 bit: 4543 D2 bit output
    RB3		EQU	3	; RB3 bit: 4543 D3 bit output
    SA_LED		EQU	4	; RB4 bit: Free-running & no DCF signal LED output
    DCF_LED		EQU	5	; RB5 bit: DCF77 Beat LED output
    BEAT_LED	EQU	6	; RB6 bit: 0.5sec Colon Beat LEDs output
    LD		EQU	7	; RB7 bit: Blank output to 4543 LD input
    ; PORTC assignments
    ERR_LED		EQU	0	; RC0 bit: DCF77 Error LED output
    AM_PM		EQU	1	; RC2 bit: AM/PM Indicator output
    CCP1		EQU	2	; RC2 bit: PWM output to 74HCT238 E3 input
    GONG		EQU	3	; RC3 bit: Gong output to SAE800
    RC4		EQU	4	; RC4 bit: 74HCT238 A0 bit output
    RC5		EQU	5	; RC5 bit: 74HCT238 A1 bit output
    RC6		EQU	6	; RC6 bit: 74HCT238 A2 bit output
    OK_LED		EQU	7	; RC7 bit: DCF Frame OK LED output
    CD :)
  9. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    Part 2
    Part 2: Initialization
    Code:
    ;                               - Initialisation -                            *
    INIT
    	CLRF	STATUS		; Do initialization, select bank 0
    	CLRF	INTCON		; Clear int-flags, disable interrupts
    	CLRF	PCLATH		; Keep in lower 2 KByte
    	CLRF	TMR0		; Clear Timer0
    	CLRF	TMR2		; Clear Timer2
    	CLRF	TMR1H		; Clear Timer1 upper byte
    	CLRF	TMR1L		; Clear Timer1 lower byte
    	CLRF	PORTA		; All PORTA output should output low
    	CLRF	PORTB		; All PORTB output should output low
    	CLRF	PORTC		; All PORTC output should output low
    	CLRF	ADCON0		; Clear ADC register
    	CLRF	ADRESH		; Clear A/D High result register
    	BSF	STATUS,RP0	; Select Bank1
    	MOVLW	B'00111111'	; RA0-5 inputs
    	MOVWF	TRISA
    	MOVLW	B'00000000'	; RB0-7 outputs
    	MOVWF	TRISB
    	MOVLW	B'00000000'	; RC0-7 outputs
    	MOVWF	TRISC
    	MOVLW	B'10000010'	; Prescaler 1:8 for Timer0
    	MOVWF	OPTION_REG	; Assign Prescaler to TMR0
    	MOVLW	H'0E'		;
    	MOVWF	ADCON1		; RA0=AN0, LEFT justified, RA1-5=digital I/O
    	CLRF	ADRESL		; Clear A/D Low result register
    	; Initialize PR2 value
    	MOVLW	D'63'		; for 8-bit PWM resolution
    	MOVWF	PR2
    	BCF	STATUS,RP0	; Select Bank0
    	MOVLW	H'81'		;
    	MOVWF	ADCON0		; Fosc/32, select Channel 0 (AN0), A/D is on
    	MOVLW	B'00000100'	; Enable TMR2, PostScaler=1, PreScaler=1
    	MOVWF	T2CON		; PWM frequency = 16.000KHz
    	; Enable PWM on CCP1 and set Duty Cycle
    	MOVLW	B'00111100'	;
    	MOVWF	CCP1CON		; PWM ON, <CCPCON5:4>=11 (2 MSB's of 10-bit resolution)
    	MOVLW	D'64'		; for 8-bit PWM resolution
    	MOVWF	CCPR1L		; Set Duty Cycle to 100%
    	; Clear GPR registers (Data RAM) 20-7F (Bank0)
    	MOVLW	0x20		;
    	MOVWF	FSR		; Initialize pointer to first RAM location
    NEXT
    	CLRF	INDF		; Clear INDF register
    	INCF	FSR,F		; Increment pointer
    	BTFSS	FSR,7		; All done?
    	GOTO	NEXT		; No, clear next
    	; Check TZ0 & TZ1 jumpers and set TZ0F & TZ1F flags accordingly
    	BTFSC	PORTA,TZ0	; Read TZ0 jumper, skip if 0
    	BSF	FLAG1,TZ0F	; No, set TZ0F flag
    	BTFSC	PORTA,TZ1	; Yes, read TZ1 jumper, skip if 0
    	BSF	FLAG1,TZ1F	; No, set TZ1F flag
    	; Check for Time Zone CET
    	MOVF	FLAG1,W		; Load FLAG1
    	ANDLW	B'11000000'	; Mask 2 MSB's from FLAG1
    	SUBLW	D'192'		;
    	BTFSC	STATUS,Z	; Timezone=CET? (TZ0F & TZ1F=1), skip if clear
    	BSF	FLAG2,CET	; Set CET flag
    	; Initialize Time Check values
    	MOVLW 	D'22'
    	MOVWF	TIME_OFF_H
    	MOVLW 	D'59'
    	MOVWF	TIME_OFF_M
    	MOVLW 	D'03'
    	MOVWF	TIME_ON_H
    	MOVLW 	D'01'
    	MOVWF	TIME_ON_M
    	; Initialize Clock variables
    	MOVLW 	D'00'		; Init Seconds
    	MOVWF	SEC
    	MOVLW 	D'00'		; Init Minutes
    	MOVWF	MIN
    	MOVLW 	D'12'		; Init Hours
    	MOVWF	HOUR
    	; Initialize Calendar variables
    	MOVLW 	D'00'		; Init Years
    	MOVWF	YEAR
    	MOVLW 	D'01'		; Init Months
    	MOVWF	MONTH
    	MOVLW 	D'01'		; Init Days
    	MOVWF	DAY
    	; Enable interrupts for Timer0
    	MOVLW	B'10100000'
    	MOVWF	INTCON		; Set GIE and T0IE
    	; Disable interrupts for Timer1 & Timer2
    	BSF	STATUS,RP0	; Select bank 1
    	BCF	PIE1,TMR1IE
    	BCF	PIE1,TMR2IE
    	BCF	STATUS,RP0	; Select bank 0
    CD :)
  10. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    Part 3
    Part 3: The Interrupt Service Routine
    The displays are updated every 2msec, DCF decoding and Clock update every 4msec.
    Code:
    ;                 - Interrupt Service Routine (every 2.0ms) -                 *
    INTERRUPT			; Interrupt Service Routine
    PUSH
    	MOVWF	W_TEMP		; Copy W to W_TEMP register
    	SWAPF	STATUS,W	; Swap status to save into W
    	CLRF	STATUS		; Bank0, regardless of current bank
    	MOVWF	STATUS_TEMP	; Save status to STATUS_TEMP register
    	MOVF	PCLATH,W	; Copy PCLATH into W
    	MOVWF	PCLATH_TEMP	; Save PCLATH to PCLATH_TEMP
    	CLRF	PCLATH		; Page 0, regardless of current page
    ;	CLRWDT			; Clear Watchdog Timer
    	INCF	CTR1,F		; Increment CTR1 (delay for Main Routine)
    	INCF	CNT2,F		; Increment CNT2 (delay for Scrolling Routine)
    	INCF	CNT3,F		; Increment CNT3 (delay for Date Display Routine)
    	INCF	CNT4,F		; Increment CNT4 (delay for hourly gong pulse)
    	; DCF77 and Clock routines are called every 2 interrupts (every 4msec)
    	; Display routine is called every interrupt (every 2msec)
    	BTFSS	FLAG2,ISR	; Check ISR flag, skip if set
    	GOTO	PASS_0		; No, ISR=0, Update DCF, Clock & Display
    	BCF	FLAG2,ISR	; Yes, ISR=1, clear ISR flag for next pass
    	GOTO	PASS_1		; Only update Display
    PASS_0
    	BSF	FLAG2,ISR	; Set ISR flag for next pass
    	PAGESEL	(DCF77)		; Select Program Memory Page of routine
    	CALL	DCF77		; Call DCF77 decode routine
    	PAGESEL	(CLOCK)		; Select Program Memory Page of routine
    	CALL	CLOCK		; Update Clock routine
    PASS_1
    	PAGESEL	(DISPLAY)	; Select Program Memory Page of routine
    	CALL	DISPLAY		; Update Display routine
    	CLRF	INTCON		; Clear INTCON Register (& clear TMR0 Overflow bit)
    	BSF	INTCON,5	; Enable Timer0 Interrupt
    POP
    	MOVF	PCLATH_TEMP,W	; Restore PCLATH
    	MOVWF	PCLATH		; Store W into PCLATH
    	SWAPF	STATUS_TEMP,W	; Swap STATUS_TEMP into W
    	MOVWF	STATUS		; Store W into STATUS register
    	SWAPF	W_TEMP,F	; Swap W_TEMP
    	SWAPF	W_TEMP,W	; Swap W_TEMP into W
    	RETFIE			; Return & enable interrupts
    CD :)
  11. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    Part 4
    Excerpt of Display routine:
    Code:
    ;       - Display BCD values of D1 to D6 to LED Display and check LEDs -      *
    DISPLAY	; every 2.0ms = 500Hz/digit, = 83.2Hz refresh rate for the 6 digits
    	MOVLW	D'6'		;
    	SUBWF	DIGIT,W		; DIGIT=6?
    	BTFSC	STATUS,Z	; Skip if DIGIT is different from 6
    	CLRF	DIGIT		; Yes, DIGIT=6, clear digit number
    	; Disable latch to 7-segment display just before sending new value to 4543
    	BCF	PORTB,LD	; Disable 4543 Latch
    	; Output digit value to 4543
    	MOVF	PORTB,W         ; Read PORTB bits
    	ANDLW	B'11110000'     ; Mask bit 4 to 7
    	MOVWF	TEMP            ; Save it for later
    	MOVF	DIGIT,W         ; Recall digit number (0 to 5)
    	ADDLW	H'50'           ; Point at register to display (D1 to D6)
    	MOVWF	FSR             ; Use as pointer
    	MOVF	INDF,W          ; Get value of register pointed to into W
    	XORWF	TEMP,W          ; Exclusive OR with TEMP
    	MOVWF	PORTB           ; BCD output to 4543
    	INCF	DIGIT,F  	; Next digit number (0 to 5 for 4543, 1 to 6 for 74HCT238)
    	; Select digit to lit
    	MOVF	PORTC,W         ; Read PORTC bits
    	ANDLW	B'10001111'     ; Mask bit 0 to 4, bit7
    	SWAPF	DIGIT,W		; Swap lower and higher nibble of DIGIT into W
    	MOVWF	PORTC           ; BCD output to 74HCT238
    	; Latch digit to 7-segment display
    	BSF	PORTB,LD	; Enable 4543 Latch
    	RETURN
    Let me know if you need more information.
    CD :)
  12. eutronix
    28 Nov 2005
    Yes! That is very helpful. Thanks! I'll see if we can't find out what we did wrong. Our circuit is a common cathode system and is arranged a little differently than yours, so it will have to be somewhat different.
    Thanks again,
    Stu
  13. Sergei Frolov
    Sergei Frolov What's a Dremel?
    4 Dec 2005
  14. salb203
    salb203 What's a Dremel?
    20 Nov 2004
  15. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    Hi Sal,
    Thanks, I already found this auction.
    But as I'm a little low on cash at the moment and I already own the above mentionned 5+1 Nu-Metric numitrons I prefer to use these to build a PIC-based clock (BTW, do you have one Apollo/IEE DA-1300 or 1310 numitron tube that you're willing to sell?)
    Nice numitron clocks! :thumb:
    It seems thet you have your own stock of MM5314 clock chips... :naughty:
    BTW, I bought a used display board from a Fluke 8200 on eBay for $10.00.
    The board contains four B-5750 nixie tubes and one B-5866 +,- polarity indicator, all in very good condition.
    Now I'm able to refurbish my Fluke 8100A digital multimeter:
    As you can see the polarity nixie tube is quite darkened.
    I received this Philips PM2422 for free, all I had to do was drive 220 miles with the Harley to pick it up... :naughty:
    Regards,
    Chris :)
  16. I'm_Not_A_Monster
    I'm_Not_A_Monster Hey, eat this...
    22 Dec 2003
    there ought to be a sticky for BCD or 7SLED clocks. there are two 7SLED clock threads on the front page of the electronics forum right now! i know i've posted my own BCD and 7SLED threads, this could save a lot of time (and bandwidth).
    maybe even a "common projects" sticky, with instructions for the most commonly posted thread topics...
  17. LennardV
    LennardV What's a Dremel?
    15 Dec 2005
    Hi,
    While searching for some info on how to build my own 7-segment clock I found this thread. And there is a lot good info in here.
    But I actually got a question for Turbokue
    as it seems to me that the schematic you posted is exactly what i'm looking for. Except from the fact I don't need the LDR option or remote control unit, and I'm not displaying seconds or points between the hours/minutes. But it seems to me I can strip out most of it without much trouble. But I'm just asking to be sure.
    And what do IC-4 and IC-5 do?
    thanks anyway, you've been of great help already
    :clap:
  18. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Rather than fill the first page with stickies, I've added a section to the first post in Useful Links to cover stuff like this that's got a lot of info and attention, so any more examples, let me know and I'll add them. Ideally, the threads should give enough info for somebody competent to complete the project, but it's also a showcase so you don't have to give all your secrets away. ;)
  19. LennardV
    15 Dec 2005
    Hey Turbokeu
    I did some small modifications on your schematic and I was wondering if I made some big/small mistakes... And I've got some open wires, don't know what they do and where they should go..
    The idea I had in mind (if it's ok with you) is to use the same PIC program with a slightly different clock...
    I tried to strip out the brightness controll, seconds indicator and beats... And I chose to multiplex the other way you posted a while ago. Realised right now I don't even need the DS2 singal as I've only got 4 displays
    Anyway, this is what I've got so far
    thanks
    Lennard
  20. Turbokeu
    Turbokeu Minimodder
    30 Jul 2002
    You're welcome Lennard!
    Yes you can strip out most of these features but ideally the ASM-code should be modified accordingly too.
    IC4 and IC5 are drivers.
    The 4543 and 74xx238 are not able to sink or source the current needed by the displays, therefore I used common high side UDN2981 (or TD62783A) and ULN2803 low side drivers to drive the displays.
    CD :)
    PS: I will answer your 2nd post a little later (have to go to the restaurant now... :naughty: )
