Modding 70mm fan grills?
Discussion in 'Modding' started by Shogun, 16 Dec 2003.
  1. Shogun
    Shogun Banned
    18 Jul 2002
    Ive searched all over the net and can not find a supplier of 70mm fan grills. Any help appreciated :p
  2. Xgamer
    Xgamer New Member
    29 Oct 2003
    Do they even make 70 mm fans or fan grills? :eyebrow:
  3. Shogun
    Shogun Banned
    18 Jul 2002
    yes they do, some hs manufacturers make them (akasa does im sure of that) but the fans are really hard to replace and i cant find any fan grills :waah:
  4. Bossman
    Bossman New Member
    6 Nov 2003
    Maplin used to sell them but they dont seem to anymore.
  5. Xgamer
    Xgamer New Member
    29 Oct 2003
  6. Shogun
    Shogun Banned
    18 Jul 2002
    that looks good, i wish i lived in the US tho :waah:
    the search continues, im also looking for 70mm-80mm fan adapters. I think these will be impossible for anyone to find tho. Any ideas on how to make one?
  7. kong
    kong cnc-guy
    24 Feb 2002
    Piece 'a cake. (Well, on a cnc router!)
  8. Shogun
    Shogun Banned
    18 Jul 2002
    how much? :lol:
    im only a lowly student :waah:
  9. jezmck
    jezmck Well-Known Member
    25 Sep 2003
    couldn't you just mod an 80mm one?
  10. Shogun
    Shogun Banned
    18 Jul 2002
    It would prob look crap if i did it. I would like a professional looking one. :lol:
  11. kong
    kong cnc-guy
    24 Feb 2002
    I think jazzle has the right idea, cut a 70mm hole in a piece of acrylic, then run a router with a chamfer bit around the edge to blend it into an 80mm hole.
  12. Shogun
    Shogun Banned
    18 Jul 2002
    I dont have any acrylic left :sigh:
  13. Dazbo666
    Dazbo666 New Member
    16 Dec 2002
    Kong, ya beat me to it - that's exactly what I was thinking about earlier ;)
    Was trying to find some templates for 70mm and 80mm grilles, but your pic is better quality that i could have done (as I only have MS Paint installed ATM !!)
  14. kong
    kong cnc-guy
    24 Feb 2002
    *kong bows*
    Shogun, a big block of acrylic is gonna cost you some even before machining, so if you are skint, you must make do with what you have. It may be an idea to simply make a 70mm hole in a piece of metal/plastic drill the two sets of mounting holes for each size fan, and call it done. Once the fan goes on, you shouldn't see it anyway. :confused:
  15. Dazbo666
    Dazbo666 New Member
    16 Dec 2002
    If you use the body of the 80mm fan as a template, there should be no problem...
    and thinking about it I may try this method with my own case - using an undervolted 92mm or even 120mm fan to reduce the noise from cooling my CPU ??
  16. Bmw M3
    Bmw M3 New Member
    24 Dec 2003
  17. tk421
    tk421 Idiot.
    15 Jan 2002
    my 70mm fan is the only one in the house without a grill on it ... it makes less noise without it ... and when i crank it up to 6k it screams as it is ..
    i want to make a 70mm<92mm adaptor for it ... with a 15 deg. rise towards the rear ... i love my volcano7+ heatsink, but i am growing weary of the fan it came with :(
