Graphics 7790 vs 7850?
Discussion in 'Hardware' started by Gunnzie, 30 Jul 2013.
  1. Gunnzie
    Gunnzie What's a Dremel?
    17 Jul 2013
    I bought a Gigabyte 7790 2Gb GPU but a friend reckons I would have been better off spending the same on a secondhand 7850. I am still within the 7 days to return the 7790 so just wondered if I should return it.
    The rest of my spec is AMD 955 BE, ASUS M3N78-VM MB, and 8Gb DDR2 1066 ram. Nothing is overclocked as I don't know how to and prefer the peace and quiet anyway ;)
  2. Harlequin
    Harlequin Modder
    4 Jun 2004
    how much was it?
    new 7850`s are about £110 on special and you can get a 7870LE (7950 light) for under £160
  3. Gunnzie
    17 Jul 2013
    I paid £118 for the 7790 from Amazon. Really? You can get new 7850 2Gbs for £110?
    I tend to only buy MSI, Gigabyte or Asus though.
  4. Harlequin
    Harlequin Modder
    4 Jun 2004
  5. Gunnzie
    17 Jul 2013
    How much better is it though? I am not sure I can bothered with the hassle now.
  6. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    It's much better. I would send it back that sounds really expensive for a 7790.
  7. spolsh
    spolsh Multimodder
    4 Feb 2012
    Reviews show it to be a lot better. If I were you, I'd get it sent back and get the better card. (I made a similar mistake a couple of years ago with a 6790).
    Teelzebub likes this.
  8. Harlequin
    Harlequin Modder
    4 Jun 2004
  9. Gunnzie
    17 Jul 2013
    Thanks for all the info then. I am going to get it replaced.
    Will 1Gb be enough? I originally went with a 2Gb card as I only had 4Gb memory but I've now added another 4 anyway.
  10. Harlequin
    Harlequin Modder
    4 Jun 2004
    what screen res are you running? anything really below 1080P and it should be fine
  11. Gunnzie
    17 Jul 2013
    1400x900
  12. teppic
    teppic What's a Dremel?
    18 Jul 2011
    You can get 7790s for £80. They're great cards for the money, but not good next to a 7850.
  13. Harlequin
    Harlequin Modder
    4 Jun 2004
    Same res as my kids machine. 1gb will be fine
  14. Elton
    23 Jan 2009
    Do 2GB. Might as well. VRAM usage gets intense quicker nowadays.
    AT 1600x1200 (which is actually a surprisingly dense resolution) I hit +1GB of VRAM easily.
  15. scuppy
    scuppy Minimodder
    26 Apr 2011
  16. bartiszon
    bartiszon Minimodder
    25 Aug 2010
  17. Gunnzie
    17 Jul 2013
    Thanks everyone. It is clear that I have made a poor choice when it comes to cost/performance ratio.
    By all accounts I should return it but I am leaning towards not bothering. I know it is the wrong choice but I am very busy and I do love that this card is completely silent and uses less power as my PSU is very old. I know 7850s are very quiet too and are not exactly power hungry by any means but I have had so many problems with my PC when changing components in the past that I think I might just live it it.
    I've definitely learnt my lesson though and will do more research in the future before purchasing anything. Thanks.
  18. Harlequin
    Harlequin Modder
    4 Jun 2004
    dude! just start the return and order the enw one - you`ll be all sorted in no time!
    request a return then wander off to the post office (or collectplus) and send the 7790 off - order the 7850 and voila all good!
  19. Gunnzie
    17 Jul 2013
    Thing is I really want a 2Gb. I haven't got a really good reason for that but I have 2Gb now so want to stick with it. I can't find a 2Gb 7850 for much less than £150 which means finding another £32. Not a huge amount but £118 was already above my original budget.
    Thanks though mate. I know you are right.
  20. Harlequin
    Harlequin Modder
    4 Jun 2004
    my kids have an acer 1400x900 19" screen with a 1 gb 6670 - even with 4x AA pretty much all of there games don't use all of the ram available
