Graphics 7800GT vs 7800GTX
Discussion in 'Hardware' started by Sva4g3&*, 12 Oct 2005.
  1. Sva4g3&*
    Sva4g3&* What's a Dremel?
    15 Jun 2004
    What is the difference between the 7800GT and the 7800GTX? And why is the GTX $80 more?
    -Rob
  2. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    The GTX is faster.
  3. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    It has 24 pixel pipelines versus the GT's 20, and is clocked higher IIRC.
  4. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    but what does that mean in real terms... is the extra performance worth the extra price?
  5. hitman012
    hitman012 Minimodder
    6 May 2005
    Many will say that it's not really, but if you get a high-clocked 7800GTX like a Gainward Golden Sample or an XFX Extreme Gamer Edition then the performance gap starts to widen a lot more - I think that's the point where the GTX becomes worth the money.
  6. Tim S
    Tim S OG
    8 Nov 2001
  7. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    Would would be better for the price, 2x 7800GT or 1 x 7800GTX?
  8. malccy72
    malccy72 Minimodder
    9 Jan 2005
    I'd go with 1 x 7800GTX; will still be faster than 2x 7800GT's in many applications and of course you can get another in future.
  9. Tim S
    Tim S OG
    8 Nov 2001
    I disagree - the 7800 GT SLI performs better than 1 7800 GTX in most instances. The "SLI doesn't work in all games" isn't the case because you can make 99% of games work with SLI by making your own profiles.
  10. MrWillyWonka
    25 Jul 2004
    Are you saying the 1x GT works better than 1x GTX, or 2x GT works better than 1x GTX? I say the latter?
  11. malccy72
    malccy72 Minimodder
    9 Jan 2005
    Sorry but I think you mean latter (2 xGT works better than 1 GTX).
  12. MrWillyWonka
    25 Jul 2004
    Oops, yes I mean the latter - edited!
  13. Tim S
    Tim S OG
    8 Nov 2001
    yes, I forgot to add SLI - been a hectic day so far! :blush:
  14. Goth
    Goth What's a Dremel?
    17 Oct 2004
    agree with bigz... example: 2x7800GT performs 2 times better in FEAR than the 1x7800GTX
  15. Sva4g3&*
    15 Jun 2004
    Right on, well thanks for the help! And how well do these badboys overclock?
    -Rob
  16. Tim S
    Tim S OG
    8 Nov 2001
    both the GT and GTX tend to overclock pretty well from my experiences :)
  17. Firehed
    15 Feb 2004
    Not to jack the thread, but is the ram/core mounting hole layout the same as the 6800GT/U?
  18. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    *Was wondering the same thing*
  19. Pookeyhead
    30 Jan 2004
    2x GTs may be better in some cases than 1xGTX, but you've lost your upgrade path. I'd opt for 1x GTX, and then add another one at a later date.
    It depends, like som many things, on your budget. If you know you can't afford another GTX later, then maybe there's no point, but I can't help thinking that if you can afford TWO 7800GTs NOW, then surely you must be able to.
  20. blue_lawnchair
    blue_lawnchair What's a Dremel?
    25 Mar 2005
    Between both cards which on yields better overclocks?
