800 to spend..help me out
Discussion in 'Hardware' started by EddieR, 31 Oct 2006.
  1. EddieR
    EddieR What's a Dremel?
    31 Oct 2006
    i have around 800 and im looking to build a tower.. what do u recommend I get??
    What would u get with 800??
    I dont need monitor, keyboard or mouse..
  2. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    In future you should post this to hardware and OCing.
  3. Will
    Will Beware the judderman...
    16 Jun 2001
    Moved to the right place for this sort of question...
  4. wharrad
    wharrad What's a Dremel?
    26 Jul 2003
    Do you mean £800 or something else?
  5. EddieR
    31 Oct 2006
    800 US
  6. Lazlow
    Lazlow I have a dremel.
    8 Aug 2003
    That's, what? £400 UK? Either a 3800 X2 budget AM2 system, or a pre-built desktop.
  7. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    Core2duo E6300, Gigabyte DS3, a gig of DDR2 667, enhance ENS5150, a 7600 series card, and whatever else case, dvd burner, hard drive, etc.
    Lazlow, in the US, $800 will get you a LOT farther than $800 in the UK. in the uk everything is like, 800£ for what you would get $800 at in the states. pretty much.
  8. Lazlow
    8 Aug 2003
    Ah, completely forgot about our 'rip-off Britain'.
  9. overdosedelusion
    overdosedelusion I mostly come at night, mostly..
    29 Oct 2006
    queeny doesnt get her custom gold carraiges for free you know
  10. Lazlow
    8 Aug 2003
    Maybe 50 years or so ago, but now it's the MPs and their Jags :eyebrow:
  11. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
  12. Nnyan
    Nnyan What's a Dremel?
    23 Jun 2004
    Bbq.of.DooM pretty much has the solid rec for that price range, depending on whether or not you'll be doing any overclocking etc... I would make a few minor tweaks to that but otherwise solid.
    I just built two systems for friends that had VERY strict $800 budgets (LCDs in hand already):
    $181.99 Intel Dual C2D E6300 CPU
    $ 56.99 ASRock 775Dual-VSTA*
    $214.99 A-Data ADQPE1A16K 2X1GB DDR2 667**
    $ 88.99 3D Fuzion 3DFR76256GSE 7600GS***
    $ 69.99 Antec NSK 4400 w/ 380W PS****
    $ 69.99 Samsung SP2504C 250GB HD
    $ 30.99 NEC 18X DVD+-R DVD Burner
    $713.82
    $794 TOTAL (w/ ship/taxes)
    * Very little if any default overclocking (but using the Core 2 Duo Voltage Boost mod I found at vrzone.com I got some very decent OC for the price).
    ** You could save a few bucks with other generic ram but I had great success with these.
    *** Yes the mobo PCI-E is limited to 4X but it can handle this card with no impact on performance based on the testing I did.
    **** Too many case choices and many that are cheaper but I found this combo to be high quality as long as you're not going overboard.
    Ran two instances of Prime95 on these boxes for 72+ hours with no burps, for the money they are nice little systems. You could save some money by buying a Pentium D instead but I prefer the Core 2 Duo.
  13. wharrad
    26 Jul 2003
    Nnyan's got a pretty good setup there. Don't think you'll go too far wrong with that.
    However...
    Dispite the budget limits I do think the motherboard may hold back upgrade potential and changing a mobo is a pain in the a***. Maybe over the next year or two you'll want to go to DX10 and Vista. PCI-E x4 will hold you back graphically with more powerful cards in future and I would guess in a couple of years we'll be discussing the advantages of 4Gigs of RAM.
  14. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    The motherboard could be changed for the ABIT SG-95 at $2 less of a cost. This way you get around the x4 limit on the PCI-E for future upgrades, and ABIT is a pretty good manufacturer for mobos! The only disadvantage of the SG-95 is that it's micro-atx, so less PCI slots
  15. customh
    customh conflagration.
    22 Oct 2005
    Sorry OT, but it says in the article...
  16. Callum
    Callum What's a Dremel?
    4 Apr 2006
    It would have been about £12,000 for me... and I'm still a UK Citizen, just living abroad. Hence Canada! :D
    On topic:
    I like what Nnyan put together for you, but I might suggest going for a single stick of 1 GB of RAM at first, and putting the money into the motherboard instead. Another stick of 1GB RAM can easily be bought later and then added to the system, but you won't be able to upgrade the motherboard anywhere like as easily.
    Plus the motherboard is the backbone of the whole system... worth putting money into.
  17. Gravemind123
    26 Aug 2006
    If you do go with one stick of ram, get a good P965 chipset motherboard, like the ASUS P5B-E or the Gigabyte GA-965P-DS3.
