Hi, Simple question really. At the moment I have an Enermax Revolution 850w, is this enough to run 2x 5870 in crossfire or would I need to upgrade to do that? Thanks
Would be enough matey. Obviousy need 4x 6 pins though or 2x 6 2x 8 (that aso work as 6 ike on aot of psu)
even my Hx620w is not breaking a sweat doing 5870 + gtx260. (both rated at around 180w) so your 850 will be more than perfectly fine.
Quick question wuyanxu - I have the same PSU, but it only has 2x PCI-E connectors. Do you just use the molex to PCI-E adaptors to power the additional card?
