Graphics 8800 GT
Discussion in 'Hardware' started by C:\Joshy, 16 Jan 2008.
  1. C:\Joshy
    C:\Joshy How much cake can you eat in a min?
    30 Aug 2007
    hi, i have just built myself a new computer, and am starting to get into gaming, obviously i will need a good GPU. i started off by looking at the XFX 8600 gts but was told they where not verry good. after a bit more looking i looked at the 8800 GT.
    just wondares if this would be any good??
    Thanks
  2. radodrill
    radodrill Resident EI
    14 Mar 2006
    The 8800GT is a good choice for Best Bang for the Buck
  3. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    very good card, the G92 chip seems to perform second to none
  4. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    I'm very pleased with mine. :)
    (Its at least twice as fast as the 8600GTS)
  5. G0RD0N FAN
    G0RD0N FAN Jeff Gordon #24
    16 Jan 2008
  6. DaveVader
    10 Aug 2007
    I've heard the 1GB version is a waste. The 512 will be suffice.
  7. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    If you get a 8800GT choose between the Gigabyte ones and the ASUS cards. they've got the fastest frame rates for stock cards
  8. Angleus
    Angleus What's a Dremel?
    28 Nov 2007
    Yeah you really dont need 1Gb of gaming RAM especially on an 8800GT, go for the 512 version or even the 256 if your using anything smaller than a 20 inch screen
  9. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    i spy a good quadro mod in that card.....
  10. badders
    badders Neuken in de Keuken
    4 Dec 2007
    My EN8800GT has the Asus cooler on it (the big fan thing, NOT the reference cooler) and will clock at 700MHz Core, 1750MHz Shaders and 2GHz RAM and stil stay under 80 degrees C.
    I was worried about the RAM not having any heatsinks on but I think they get a lot of airflow from the Cooler, and I've noticed no artifacts.
    Just a pity Asus bungled the BIOS so only Asus Smartdoctor can read the GPU temp.
  11. Krikkit
    21 Jan 2003
    What? Reference design cards are made by someone else, then branded have no differences. Any frame-rate differences are just luck.
    Also the 1GB frame buffered version is total marketing, the GT's very limited by memory bandwidth as it is, there's no way it can realistically use all that memory properly...
  12. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    Yeah there is the reference card but companies have their own core clock rates, memory clock rates and shader clock rates on the cards. (for example: GIGABYTE core clock = 750mhz while the Asus top edition's core clock = 700mhz) all the cards have different clock rates thats why some are better than others.
  13. radodrill
    14 Mar 2006
    For the most part the physical hardware is the same; vendors simply apply their sticker to the cooler (or install a custom cooler) and flash their BIOS to them. Any differences in the BIOS are the clock speeds and possibly some tweaks to the RAM timings or voltages. I go with eVGA, BFG, or XFX since they offer a lifetime warranty.
  14. SPQQKY
    SPQQKY Evil Modder
    7 Jul 2007
    I would go with the Asus. Better cooler and yes, the BIOS are a bit tweaked better. Lifetime warranty means about squat, they know no one will keep a video card for a lifetime. The Asus also carries a nice price. The only piece of hardware I've ever had arrive DOA was an XFX 6800Ultra....since then, I stay away. Probably just bad luck, but it leaves a bitter after taste. Other than Asus I'd consider MSI, eVGA or BFG.
    Basically you can't go wrong with any of the 512MB 8800GT's, it's a great card for a nice price. I've seen a lot of them drop down to $250 which is the same price as the HD3870 and since it performs better, it's the smartest buy right now.
  15. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    i personally intend to go with a evga card for step-up, better find out if that is a international thing first thou
  16. BlueTrin
    BlueTrin What's a Dremel?
    15 Dec 2007
    Well I know that I would be pissed off if my card would burn right after 1 year, if I was on a one year warranty ...
  17. biff
    biff What's a Dremel?
    8 Jan 2004
    The Asus cards have 3 years... might as well be lifetime. I'm sure in the year my nice new 2011 my 8800GT will be in my office computer running Word. Even my 1 y/o X1900XT is on a shelf waiting to be pawned off.
  18. Guest-23315
    Guest-23315 Guest
    I love my 8800 GT. Have fun with one!
  19. EternalIllusion
    EternalIllusion What's a Dremel?
    23 Feb 2005
    About to get one myself since i am upgrading very soon. I think the lifetime warranty is def a bonus; when you do sell it, it'l be a better value for potential buyers.
  20. SPQQKY
    SPQQKY Evil Modder
    7 Jul 2007
    Honestly, the lifetime warranty is not a bonus, especially since it's only good for the original owner as is eVGA's step up program. And I looked into the step up when I had an eVGA card, the cost is alarming. I saved $100 by just selling the card and getting the latest one rather than use the program.
