Graphics 8800 gtx problemo
Discussion in 'Hardware' started by pigme1000000, 4 Dec 2007.
  1. pigme1000000
    pigme1000000 What's a Dremel?
    29 Sep 2007
    im running 1 8800gtx at the mo and ive got my eye on a freinds faulty gtx,the problem is when the monitor is pluged into the dvi slot the pic is distorted!! if i ran my good card and the faulty one in sli mod useing my good cards dvi,would this work and be ok?
  2. Krikkit
    21 Jan 2003
    That depends what's wrong with the other GTX - if it's just something in the output stage of the card it'd probably be alright, but if it's within the processing stage you'll have no luck tbh.
    I'd suggest you just RMA your friends' card if possible. :)
  3. lworbey
    lworbey What's a Dremel?
    23 Nov 2007
    If you are meaning in games and you are running on a TFT is could be a VSync issue, try turning on VSync to see if that fixes the problem...
  4. wyx087
    15 Aug 2007
    run ATI Tool on your distorted computer, if there's errors detected, i suspect it's wrong with the processing stage.
