Linux 8800gts 512 and linux
Discussion in 'Software' started by notatoad, 23 Jan 2008.
  1. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    has anybody here got the new g92 cards working under linux? i tried booting up ubuntu for the first time since i got mine, and it popped me into "safe graphics mode". i figured no problem, i'd just reinstall the driver. but then the latest nvidia binaries in the repository don't work with the card, and the restricted drivers manager can't even see it.
    i'm going to try manually installing the driver off nvidia's website next. how do i get Xorg turned off? i tried going doing telinit 3 and then killall xorg, but X just restarted automatically.
  2. Glider
    Glider /dev/null
    2 Aug 2005
    ctrl + alt + F2
    and then
    Code:
    sudo init 3
    or
    Code:
    /etc/init.d/gdm stop
  3. 123mccann
    123mccann What's a Dremel?
    16 Dec 2007
    Which Distrobution are you using?
  4. Elv13
    Elv13 What's a Dremel?
    26 Apr 2006
    you have to download the driver from nvidia website,
    sudo su
    cd <path to driver>
    chmod 777 <driver name>
    ./<driver name>
    follow instruction and all will be find. I use a 8800gt right now and exept few visual glith at 3360x1050, it work perfectly
  5. notatoad
    25 Jun 2004
    thanks for the help guys. that did it.
