Memory 8GB DDR3 Non-ECC Sticks?
Discussion in 'Hardware' started by PaulRincon, 12 Mar 2011.
  1. PaulRincon
    PaulRincon What's a Dremel?
    12 Mar 2011
    I am desperate to build a I7 2600K system for virtualisation and I want to max out the RAM to the full 32GB but I can't seem to find suitable RAM on the market. It's a bit annoying that we are limited to 4 slots on the boards, unlike the previous I7 boards that had up to 6.
    Can anyone kindly advise? I'm after lots of speed and lots of memory because I will be running a lot of VMs.
    I am not worries too much about the budget so if someone can suggest a good alternative then that would be great.
    Feel free to mail me some links if possible: paul.rincon@theitprofessionals.co.uk
    Cheers!
  2. murraynt
    murraynt Modder
    6 Jun 2009
    If you going down the route of virtilisation mad look at socket 1336 or wait it out for it's replacement socket 2011.
    You aren't put in 32gb yet because 8gb sticks aren't available ATM.
    Also it's best off to take down you email as you will get all sorts of spam.
  3. PaulRincon
    12 Mar 2011
    Hi Murayynt, thanks for the suggestion, I will take a look at that. Would you have any idea how long it might be before the 8GB sticks come out?
  4. javaman
    javaman May irritate Eyes
    10 May 2009
    I thought most boards had had a 16gb memory limit across all 4 slots, tho I'm pretty certain I saw 8gb sticks available.
    EDIT:Found some here and here
  5. murraynt
    murraynt Modder
    6 Jun 2009
    Didn't see them.
    Altough I know my board in sig can take up to 32GB
  6. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    A workstation board might be more called for, with more RAM slots. I'm building a quad socket F system because of these issues.
