Memory 8gb ram question
Discussion in 'Tech Support' started by NeedlesKane, 24 Jul 2009.
  1. NeedlesKane
    NeedlesKane You're a Dremel
    2 Aug 2008
    hey guys,
    hope this is the right place for this.
    ive just bought a sony vaio vgn-aw31m laptop and it says it can take up to 8gb ram (4 fitted)
    http://vaio.sony.co.uk/view/ShowPro...s&category=VN+AW+Series&assetid=1218032875460
    theres two ram slots underneath the laptop 2 x 2gb.
    does this mean there will be two more slots underneath the keyboard, was wondering if anyone knew as it would save me having to take it apart to find out.
    cheers.
  2. GoodBytes
    20 Jan 2007
    No. It says that your 4GB memory option is formed of 2 stick of 2GB.
    If you want 8GB it will be 2x4GB... meaning 2 stick of 4GB... 2 times 4 is 8.
    If you had 1 stick of 8GB of RAM, then it would be 1x8GB.. meaning 1 stick of 8GB.
    Laptop usually have 2 RAM sockets.
    The RAM location is under the laptop, there is usually a RAM compartment which varies in position between laptop models and size.
  3. dark_avenger
    dark_avenger Well-Known Member
    9 Jul 2008
    like GoodBytes said it will just be the 2 ram slots you would need to fit 2x4GB modules.
    to be honest i would not bother with the expense the change between 4-8gb isen't going to be
    huge especially on a laptop where very intensive apps (multitreaded/large memory demands) will not run very well anyway.
  4. NeedlesKane
    2 Aug 2008
    thanks for your help guys, i ask purely because i run virtual machine. which wouldve made 8 gb nice. and i had no idea you could get 4gb ddr2 sodimm :S
  5. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Not sure if you can get them, but if you ever find them they won't be cheap! :eeek:
  6. Rotcrack
    Rotcrack Food Maestro.
    24 Jul 2009
    I have never heard of a reliable 8gb stick of RAM. 2x4gb of RAM is very expensive and less reliable then 2x2gb but if you want 8gb, 2x4gb is the best.
  7. smc8788
    smc8788 ...at least I have chicken
    23 Apr 2009
    Yup, you can get them, but they generally start at around £150 each, so it's not advisable.
  8. NeedlesKane
    2 Aug 2008
    thanks again guys, ive had a look round and the cheapest ive found them is £42 a stick for 4gb. have just looked in the laptop bios and everything is locked off except boot order. so VT is inaccessible. how stupid am i for thinking vaio would give me a real bios!
  9. GoodBytes
    20 Jan 2007
    That, or your CPU doesn't support VT.
  10. thehippoz
    thehippoz New Member
    19 Dec 2008
    check tool for vmware for 64-bit guests.. you should be fine running a 32bit os as a guest on the vaio without EM64T and VT- if your running the win 7 vm, your getting the melee island marketing scheme of selling more chips! =p it should at least do old xp but I guess microsoft wants it that way..
    Processor Check for 64-Bit Compatibility
    This is a standalone processor check utility which you can use without VMware Workstation to perform the same check and determine whether your CPU is supported for virtual machines with 64-bit guest operating systems.
    Version: 6.0 | 2007/05/09 | Build 45731
    http://www.vmware.com/download/ws/drivers_tools.html
    Note: This utility is provided without support from VMware.
